Author Topic: Slighly Upsetting  (Read 2098 times)
Slighly Upsetting
« on: Sat, 20 February 2021, 14:50:26 »
So, Tp's colorimeter can't really measure True black if it's below 0.01nits
Kinda sux, cuz the pr0bes that could do it start at $5000 used,
The 2.6 Billion : 1 contrast is obviously just the sensor clipping,  this lcd only goes up to 6500:1
262621-0
Offline Coreda
Re: Slighly Upsetting
« Reply #1 on: Sat, 20 February 2021, 14:52:34 »
What would be that dim? I can only think of OLED.
« Reply #2 on: Sat, 20 February 2021, 15:03:13 »
If you set the lcd backlight white lvl below 32.5 nits, at 6500:1 contrast,  the black level will be below 0.01nits .
Tp is trying to use the monitor in complete darkness.
Offline Coreda
« Reply #3 on: Sat, 20 February 2021, 17:42:35 »
Nice you found one with a minimum brightness at that level. Particularly handy if you can adjust it via DDC/CI with sliders or hotkeys.
