Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Off Topic
The Joy of 23.976 [Text wall]
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: The Joy of 23.976 [Text wall] (Read 2218 times)
tp4tissue
Destiny Supporter
Thread Starter
OmniExpert of: Rice, Top-Ramen, Ergodox, n Females
on:
Fri, 05 March 2021, 19:12:11 »
As y'all know 60fps has been topKek for GAMING. moving on to 120hz 144hz now 240hz and 360hz.
However, ALL mainstream m0vies are made in
23.976
Frames Per Second.
This is a throwback to old technological limitations and broadcast standards.
The premise has continued, unabated.
What happens when you playback 23.976 fps on a 60hz lcd.
You may have heard of the term
3:2 pulldown
, that means it takes the approximately 24 frames split it among 3hz, 2hz, 3hz, 2hz,
until 24 fills 60.
That's correct if the frame rate is 24fps, but since it's not, it's 23.976, what happens is the system will either
DROP or REPEAT
a frame every 40-50 seconds.
The system may also experience delays if it's not a pure playback built device, which means even if it was 24, you still get Drops or Repeats.
So what's the Big Deal
, why is 3:2 pull down bad.
Well for purists, the entire production chain is in precise 23.976hz. The Studio use panels that do exactly that, FRAME PERFECT. Each frame takes the same amount of time on screen, known as perfect cadence. This is not super critical in live action, but for things like animation / anime, it makes a HUGE difference as they use animation techniques which benefit from frame perfect playback.
3:2 is how pulldown is done, there are also other playback techniques like frame blending which some software uses. While this does make cadence appear smoother, this has the problem of reducing frame sharpness as 2 frames are blended together to create an inter-frame, a fake insert frame.
For a VERY LONG TIME, we've only had 60hz panels/ systems. But these days, Many Monitors and TVs support some sort of 23.976 friendly playback mode. They either support 23.976 /24/25/50 directly, or multiples of it like, 71.928, 119.88, etc.
If you have a 120hz or 144hz panel, that's perfect for 24FPS content like Korean movies, but it's still not perfect for 23.976, there will be Drops and Repeats. (FAR LESS) than 60hz, so if that's all your monitor supports , those modes are still better than non close multiples like 165hz or 75hz.
How to spot the problem visually, describing it is difficult, but imagine a Song, instead of ZoomZoomZoomZoomZoom, it goes, Zoooom Zoom Zoooom Zoom Zoooom. It's close but something is OFF.
Subconsciously Your brain is
very good
at discerning the difference, Once you SEE IT, you'll never want to go back to Non-frame perfect.
Overall Perfect cadence Improves motion clarity, and also Panning smoothness.
Try 23.976 Today.
Last Edit: Sat, 06 March 2021, 18:32:08 by tp4tissue
Logged
< Tp4 Keycap Project >
< Tp4 Typing Speed-Guide >
< Tp4 Rice Hydration Guide >
< Tp4 Agar.io Lessons >
< Geekhack Agar.io Team >
< Making DIY Mouse feet ? >
< Tp4's WMO Ultimate >
< Tp4's G100S >
< Tp4's Ethernet Cable Guide >
< Ergopwn 9000 >
< Tp4 External Harddrive Mod >
< Tp4 Air Filter >
< Cricket Wireless ? >
< Fastest MicroSD Card ? >
< Tp4 Comes to America >
< Olfa 9mm, The Sharpest >
< Logitech G403 Lags >
noisyturtle
Exalted Elder
comfortably numb
Re: The Joy of 23.976 [Text wall]
Reply #1 on:
Fri, 05 March 2021, 19:19:52 »
60 fps is overrated, some of my favorite games run @30 and it doesn't detract at all
I've also been known to make big fps sacrifices for visual gains though
Logged
tp4tissue
Destiny Supporter
Thread Starter
Reply #2 on:
Fri, 05 March 2021, 19:40:32 »
The problem we still have is that monitors and tvs don't REPORT what its actual behavior is. for example 60 could be 59.45hz. That's A PROBLEM, and it's difficult to deal with, if the display is not telling the truth.
Logged
< Tp4's G100S >
< Ergopwn 9000 >
< Tp4 Air Filter >
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Off Topic
