Author Topic: Who else would buy themed wrist wrests if they were included in gbs?  (Read 2450 times)
Offline xippa
  • a college student deepening his debt through keebs
    • gram
title.
Offline cthalupa
Re: Who else would buy themed wrist wrests if they were included in gbs?
« Reply #1 on: Sun, 21 March 2021, 02:07:22 »
Potentially. I don't generally use a wrist rest, though I'm about to be putting some SAs on a high profile keyboard, so that might be changing.
I think the part that I would struggle with is the material and aesthetic - I lean towards metal cases, and I would generally want something that matches. Plastic could be tough, but at the same time, I don't know that I want to wrest my wrists on metal, either - seems like it could be fairly cold when you first sit down, and then get too hot after. Wood could work - but a bit more challenging to make it match.
Which I guess is a long way of saying that it depends on execution and where I'd be putting the caps.
« Reply #2 on: Sun, 21 March 2021, 16:42:49 »
Problem is the way they print these fabrics they're not very durable, and they fade as soon as you wash them.
Offline Sup
« Reply #3 on: Sun, 21 March 2021, 17:03:51 »
I think there would be enough so long it has anime or some **** on it. Just make a Zero two wrist rest and i bet it will sell like pancakes lol.
current
Coming soon
« Reply #4 on: Sun, 21 March 2021, 21:12:26 »
Do pancakes sell well ? They're just so-so no ?
Offline cthalupa
« Reply #5 on: Sun, 21 March 2021, 21:58:13 »
Oh, I didn't even think about the neoprene/fabric ones. Yeah, those disintegrate, so I wouldn't be in on those for sure.
Offline Sup
« Reply #6 on: Mon, 22 March 2021, 06:02:47 »
It's a saying don't take it to serious lol  ;).
current
Coming soon
« Reply #7 on: Mon, 22 March 2021, 08:25:47 »
We should change the saying to Avocados,  but then peeps be like, oh well you're supporting the drug cartel.
