Author Topic: O M G, TOTD  (Read 2739 times)
O M G, TOTD
« on: Mon, 21 June 2021, 16:37:51 »
dgVoodoo works on Typing of the Dead,  The greatest typing game ever made.
Original (Default output)
Dgvoodoo
Original 640x480 locked
dgVoodoo 1920x1200, 8x Supersampling AA + Edge Detect.  Click image to zoom
270999-3
Re: O M G, TOTD
« Reply #3 on: Tue, 22 June 2021, 09:49:46 »
The social commentary in this game is prophetic.
It came out in 2001, has terms like, Don't drink the water, Endocrine Disruptor,
They're talking about Atrazine, which is made by a swedish company, it's banned in europe,  but they bribed the EPA to keep it going in the USA.  still poisoning us.
Re: O M G, TOTD
« Reply #4 on: Tue, 22 June 2021, 15:27:48 »
OMG, after all these years, finally discovered super secret move.
In order to open the menu in "Original mode" to check how many coins are unlocked,   You have to press UP and Enter together, extremely precisely and Let go same time, really fast.
If you hold up and press enter, which is what the UI indicates you should do, it will just kick you out of the menu.
If you hold either key slightly longer, it will kick you out of the menu.
Crazy bug.
Re: O M G, TOTD
« Reply #5 on: Wed, 23 June 2021, 12:54:05 »
5 Star Emperor,
In most cases at the end of the last lvl, the player won't be fighting the max difficulty emperor, because he would've lost a few lives beforehand which causes the game to auto drop the difficulty.
However, in the situation where you deliberately TRY HARD, and come across max difficulty, or playing boss mode. Some Tips.
The game gives you enough time for all of the emperor's attack patterns except the 4 balls.  On 4 balls attack, you only have to type 3 and the last ball won't hit you, you can clear all 4 balls some of the time, but not always.
It's important that you focus and start typing as soon as possible on all attack patterns because there's very little wiggle room.
Most attack patterns require A-speed to clear. The sword can go as low as C, chainsaw as low as B.
271181-0
271183-1
