Author Topic: Eagle-Eyed TEST.  (Read 2248 times)
Eagle-Eyed TEST.
« on: Sat, 04 September 2021, 12:00:54 »
Without looking at the file size.
WHICH image is web 4K stream,  Which is 4K bluray.
1
275716-0
2
275718-1
Offline Coreda
Re: Eagle-Eyed TEST.
« Reply #1 on: Sat, 04 September 2021, 12:19:31 »
First one appears to have more noise intact and better rendering of reds suggesting improved chroma subsampling. So I'd guess first is the BD.
What I'm assuming is the web stream looks very similar for that shot though.
Edit: marked in spoilers.
« Reply #2 on: Mon, 06 September 2021, 12:08:56 »
Pretty sharp. But I suspect coreda was already an expert pre test based on his explanation..
« Reply #3 on: Mon, 06 September 2021, 12:11:52 »
I might argue if you need to stare at a still image like it's a Magic Eye to see quality differences, perhaps it's totally arbitrary.
« Reply #4 on: Mon, 06 September 2021, 12:14:55 »
That's the whole purpose of compression is to look for that line.  I think they've got the science down, but here and there you really do catch the compression artifacts.
If you look at the little yellow dude, he's a different color due to the compression.
