Author Topic: Is oven "Clean" function safe ?  (Read 2492 times)
« on: Mon, 06 September 2021, 19:55:13 »
Never used it,  anyone use it ?  it sounds dangerous, pyrolytic cleaning.
Re: Is oven "Clean" function safe ?
« Reply #1 on: Mon, 06 September 2021, 20:08:27 »
Yes, it's safe and it works. There will be a fine gray ash left at the bottom that you will want to vacuum out.
The smell will be terrible.
- D Trump 2026-10-24
« Reply #2 on: Mon, 06 September 2021, 20:10:01 »
What are the odds of explosion, setting cabinets on fire ?
It says 4 hours run time ??
Offline Faceman76
« Reply #3 on: Mon, 06 September 2021, 20:12:49 »
Do it when the house is otherwise cool and you'll be fine. Otherwise your A/C may struggle to keep up.  My parents have been using this feature as long as I can remember and I've been continuing the tradition for the last 15 years without issue.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
« Reply #4 on: Mon, 06 September 2021, 20:17:33 »
Working up the courage,   will run tomorrow morning and report if not dead.
« Reply #5 on: Mon, 06 September 2021, 20:17:42 »
do it during the day when you can open all your windows, keep the vent running, and don't forget to remove any foil and trays
Offline Faceman76
« Reply #6 on: Mon, 06 September 2021, 20:44:59 »
It's a good way to cleaned stained trays as well. Just be warned that they may warp.
« Reply #7 on: Tue, 07 September 2021, 11:07:24 »
Just did it,   works,  no died..
The house smells like kiln..  chemically art room
