Author Topic: Halo  (Read 10413 times)
Halo
« on: Sat, 27 November 2021, 12:37:41 »
Finally got Halo to work.
Anyone else Playing ?
Right now it doesn't seem like a fair fight vs people with faster GPUs.
The graphics settings do not let you to turn down "ENUFF" stuff to get the same FPS as rich people.
So, on p00r Tp4's 1060,  only ~70-85fps, 1080p everything on LOW/Off,
What needs to happen is they have to change the GPU setting such that Most of the expensive features can be turned off completely.
CPU usage is 100%, wth is it doing with all that ??
Still having fun overall.  Pacing is good, the gravity is a bit wonky, but this is inherited from consoles.
Re: Halo
« Reply #1 on: Sat, 27 November 2021, 13:27:11 »
Ok, figured out the CPU  issue,  it runs like the old Mastercam, just 100% cpu if you set game's fps uncapped.
Basically, set the cap to ~20% higher than the gpu's max output.
Start with 120fps limiter, then in game watch the meter, find the max, either go up or down, add 20%
If set to unlocked, the GPU does not get to max fps, because the engine is choking the CPU.
No longer have 100% cpu, it's running at 30-40%,  my fps is ~80-100 now (Before 70-85).  So for limiter I set it to 120fps limit
Re: Halo
« Reply #2 on: Sat, 27 November 2021, 15:11:01 »
Don't think i'm addicted yet,   it's OKkkkkk..
1060 really is just not hitn' it.
Open maps 70-85
Closed maps 80-100
probably 3070 would cut cheese.. hrrrrmmmm..
I really don't like how the weapons are on the walls.
Re: Halo
« Reply #3 on: Sat, 27 November 2021, 18:29:07 »
I did not realize the multiplayer was free to play, holy crap! They give the game away with the pass, and the multi is ftp. Where are they making money off Halo Infinite?
Re: Halo
« Reply #4 on: Sat, 27 November 2021, 20:06:59 »
They do the cosmetic armor stuff,  I think the pricing is fair considering.
Right now people are complaining about the progression system, which is extremely slow if you want to build the spartan (cosmetic) parts.
I tested the game in training mode for a few hours, I think using 1080p + lowest rendering resolution so it's lower than 1080p, 100-130fps,  is the only way to be competitive on my low end Gpu.   Running the GPU at near 100% also feels like its introduced a bit more input lag.   So perhaps capping the fps to 85-95% of peak is more consistent, not totally sure about it yet. But using the Cap to lower the CPU usage is critical,  lots of input lag uncapped.
Re: Halo
« Reply #5 on: Sun, 28 November 2021, 16:42:42 »
It's definitely satisfying Shooter.  As an F2P which will improve over time, it's hard to complain.
The progression system if a bit faster would be more enticing.
I'd like them to allow lowering enough settings to achieve at least ~300 fps.
Re: Halo
« Reply #6 on: Sun, 28 November 2021, 17:33:09 »
It looks like it supports lan ?  This could be the ticket to revive LAN PARTIES.  ??
Whos' up for partying like it's 2005 when Pandemi is over  ? hahahahaha
Re: Halo
« Reply #7 on: Sun, 28 November 2021, 21:15:47 »
Not gonna lie.. slightly addicted...   That halo melee sound is so satisfying.  like crunchy celery.
This is wayyyy more fun than csgo/ fortnite.
Offline Darthbaggins
  • PC Cannibal
Re: Halo
« Reply #8 on: Mon, 29 November 2021, 06:23:36 »
Loving the new Halo, 343 did a great job.  They could tweak the hit box and hit detection a small bit, but other than that I love it.  Brings back fond memories of Halo 2 days/nights.
Re: Halo
« Reply #9 on: Mon, 29 November 2021, 07:24:04 »
Had on dat halo 2 soundtrack.. Bang'n, 17 years later.
The hit detection might be an input lag issue, what's ur framerate capped at.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Halo
« Reply #10 on: Tue, 30 November 2021, 10:59:44 »
I've been playing a lot of Halo Infinite to my surprise! I was never the biggest Halo fan when I was a kid, but I'm having a great time playing so far.
The progression & monetization could use *some* work, but it's not a huge worry for me.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: Halo
« Reply #11 on: Tue, 30 November 2021, 11:13:05 »
Long time no see, wb! :cool:
Offline phinix
Re: Halo
« Reply #12 on: Wed, 01 December 2021, 07:02:40 »
never played Halo, but tp - we should have a little GH turnament in Quake Remastered! :D
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Halo
« Reply #13 on: Wed, 01 December 2021, 09:40:06 »
I find it kinda boring tbh. Got roped into it to play with some friends, but being used to UT99 and Quake 3, this feels unpolished, lacklustre, and it looks and sounds bad. Controls aren't great, weapons extremely boring, weak and unsatisfying, environments look like crap, player models couldn't be more generic if they tried, no interesting sounds or even voice lines, music barely noticeable. It feels very much like a game with no features or content at all.
Re: Halo
« Reply #14 on: Wed, 01 December 2021, 09:47:55 »
are you talking about coop play ?
Did you do the multi-player ?
Re: Halo
« Reply #15 on: Thu, 02 December 2021, 21:00:39 »
If Tp4 only had a 3070+  Tp4 would be Awesome @ this game.
To Skip Intro movie,   replace intro moviefile  in the video folder with these blank .mp4 files
Offline goodyvee
Re: Halo
« Reply #16 on: Thu, 02 December 2021, 22:33:14 »
its alright i mean its the better of the halos in recent time
cant stand the nade spam during the game though, maybe would be better if people started with 1/0 nades
Re: Halo
« Reply #17 on: Sat, 04 December 2021, 09:01:00 »
it's only 10am , Tp4 has already played halo for 5 hours today.
/addiction !!
In game settings,  Everything Low/ Off, with exceptions of Geometry = Medium, otherwise the pop-in geo-model changes are a huge distraction.
Render resolution 71% of 1080p
Sharpening = 100%
__Halo's image Post-processing engine is TOP NOTCH.  Thanks console gaming.
fps cap set @ 135, 35-52% cpu usage.
Hopefully in the future, they will give us the options to tweak up to ~2-300fps.
Re: Halo
« Reply #18 on: Sat, 04 December 2021, 12:30:12 »
This is extremely mentally taxing.  feels like ready to go to bed.
Re: Halo
« Reply #19 on: Sat, 04 December 2021, 13:13:25 »
Contemplating busting out the CRT
Offline Skok
Re: Halo
« Reply #20 on: Tue, 07 December 2021, 01:05:44 »
mp is fun but after getting to onyx theres nothing to grind for since battle pass is ass
Re: Halo
« Reply #21 on: Tue, 07 December 2021, 02:31:13 »
Seeing a lot of GH'ers playing multi on Steam, awfully tempting
Offline chyros
  • a.k.a. Thomas
Re: Halo
« Reply #22 on: Tue, 07 December 2021, 10:53:44 »
Multiplayer with friends in the same team vs other teams.
Re: Halo
« Reply #23 on: Tue, 07 December 2021, 12:50:24 »
u guys playing xbx or pc ?
Offline chyros
  • a.k.a. Thomas
Re: Halo
« Reply #24 on: Tue, 07 December 2021, 17:59:51 »
PC, obviously. I find the insinuation that I might be a console gamer repulsive and insulting .
Re: Halo
« Reply #25 on: Tue, 07 December 2021, 18:48:19 »
Offline phinix
Re: Halo
« Reply #26 on: Wed, 08 December 2021, 02:34:26 »
hear! hear!
Re: Halo
« Reply #27 on: Wed, 15 December 2021, 10:08:09 »
Bring it on Non-Boomers.,  I WILL DESTROY YOU.
279903-0
Re: Halo
« Reply #28 on: Thu, 13 January 2022, 18:31:52 »
16:10 is a good resolution for this game, because there's quite alot of verticality on the maps, where 16:9 is more limiting.
Sure you can increase FOV but then everything is narrower to shoot at.
Offline gipetto
Re: Halo
« Reply #29 on: Sun, 16 January 2022, 04:12:22 »
you can get switches with long stems that would poke up through the monitor case. that way you don't need to find a compatible plastic button.
Re: Halo
« Reply #30 on: Sun, 16 January 2022, 10:04:27 »
Woah there,  don't wanna get "toooo" OP of a setup.
Re: Halo
« Reply #31 on: Mon, 17 January 2022, 12:43:42 »
Wish List,   Custom aspect ratio.
This way ,  On CRT for example,  We could run 1280x 767 @ 90hz, BUT stretch it out vertically to 4:3,  THEN  internally correct aspect ratio.
It actually all should be possible since the game has dynamic resolution, which means all the control surfaces are in place already.
Re: Halo
« Reply #32 on: Thu, 20 January 2022, 16:07:21 »
Recent patches seems to have fixed the texture streaming issue.
Re: Halo
« Reply #33 on: Sat, 22 January 2022, 00:36:15 »
Honestly, I wouldn't be at all opposed to them using the Halo engine for a Starcraft shooter. Ghost did before it even hit the ground, a Starcraft FPS has a ton of potential for mechanic and systems integrations.
Re: Halo
« Reply #34 on: Sat, 22 January 2022, 10:06:54 »
I think halo is already the pinnacle of FPS refinement.  It's got Exactly what Fps shooters crave.
It's extremely satisfying to get kills in Halo, because there's so much timing/physicality to it, and they've paced it perfectly such that you feel in control..
Not opposed to an SC fps, but it seems pretty hard to get solid plot driven gameplay now that we've mostly seen it all.
Offline chyros
  • a.k.a. Thomas
Re: Halo
« Reply #35 on: Sun, 23 January 2022, 16:36:39 »
WHAT ARE YOU TALKING ABOUT
IT'S SO BAD
Re: Halo
« Reply #36 on: Sun, 23 January 2022, 17:15:37 »
IT'S SO BAD
/kekeke
Chyros, Tp4 doesn't think chyros set it up properly for "Peak" experience, it's a tricky engine.
The input lag and response is totally weird if any steps were missed,   it's basically beta.
From drivers, to background task, etc.
The GPU requirement is also extremely extremely high.
Offline Sniping
Re: Halo
« Reply #37 on: Sun, 23 January 2022, 17:22:07 »
I been having a lot of fun on halo, I don't think it's the peak FPS right now though. I think the purest game out there with high skill margin, insane tech, movement and weapon control is probably apex legends. I think there's some complaints about tournament level gameplay but overall it seems like a pretty perfect FPS. if there's a game right now to dump all your hours into honing in your skill that would get my vote. I still hardly play it though because it takes a lot of hours to get good and I never bother to break into it. Watching my skilled friends play though is so crazy, especially when you play with them in game. The skill gap is super high.
Re: Halo
« Reply #38 on: Sun, 23 January 2022, 18:51:06 »
The thing I don't like about Apex is the unnecessary complexities.
So f2p fps is designed around selling skins, and they've chosen to increase the variety of the market place by making all these different guns that do not work remarkably different from one another.   And even if they are slightly different,  the questions are <why> and <is that fun> memorizing some arbitrarily large list of gun timings/handling.
Conversely, Halo has been refined in the OTHER direction.  Bread and butter guns, not a huge variety.
I don't think Apex is a bad game, but having a mini inventory to manage is counter to fps pacing,  I want kills and I want them faster, but not so fast that I don't feel the crunch, you want a cookie that's the RIGHT thickness, not too thick, not too thin.
Apex is a middle ground to the fortnite formula,  and it feels just as messy.  There's also <like> fortnite, too much empty space/ running around.  Maybe younger gen likes this,  but as an older hughmahnn Tp4 CAN NOT STAND down time, waiting around the corner or a football field away NOT moving is a time waster, I want to be having fun, not ducking.
_Halo infinite is not without mistakes.   For a solid play experience, the Engine is just too demanding.  It was made for Next Gen,  and it wasn't designed to perform well for the F2P crowd with vanilla gpus.
Offline chyros
  • a.k.a. Thomas
Re: Halo
« Reply #39 on: Tue, 25 January 2022, 01:41:58 »
IT'S SO BAD
/kekeke
TP4 am oldskool too though, right?
If you've played the likes of Quake 3, UT99, and other classic arena shooters, it should be obvious why HI is but a shadow of a game. Genuinely I don't see ANYTHING that game has going for it other than it being free. If it came out as a non-Halo title from a lesser-known developer, I doubt anyone would pay attention to it.
Re: Halo
« Reply #40 on: Tue, 25 January 2022, 09:03:52 »
In many ways HI is balanced exactly like Quak.
When setup properly, the PACING of the game, between "engagement" and "reward" is very tight, and there's "just enough" to "do" where each fight feels like a chess move.
There is alot to think about when trying to win an engagement.
It also must be played as a team,  They've built this around the team dynamic.
The addition of Controller players is also unique.  Because of controller auto-aim, that makes controller players much better at snap forward engagement vs mouse players.
So a combo is Mouse player forming the back end, who can turn around faster, and aim, while a controller player takes point, because they can use auto snipe weapons more effectively.
4 different grenades, very different effect, repulsor deflection mechanic, many different mechanics that form the play pieces.
It's an extremely Deep game.
Offline chyros
  • a.k.a. Thomas
Re: Halo
« Reply #41 on: Tue, 25 January 2022, 11:20:35 »
There's nothing deep about it at all and it doesn't play like Quake in the slightest! When's the last time you played Q3 that had regenerating health and a limited arsenal? :p
HI is basically a game of 2>1, aimbots, zero-damage, lame weapons with no gunplay to speak of, forced stranglehold teamplay, and REALLY ****ty maps. It's almost everything that makes Battlefield **** as well, except the environments are lamer. It's an obvious homage to the crappy level of gameplay that consoles drag us down to; the lowest common denominator made flesh in a game. Sometimes less content makes for a more focused whole, here's it's just an absence of content :p .
Calling HI deep is like calling Guitar Hero deep :p .
Re: Halo
« Reply #42 on: Tue, 25 January 2022, 11:30:40 »
For example, the way grenades bounce in halo can be controlled to a great extent.
It's like a whole separate game of pool/marbles within the core game.
Tp4 feels that the players get as much depth as the amount of cognition they're willing to apply.
It's unfortunate that Chyros feels the way he feels, but Tp4 recommends giving Halo more trial.
