Author Topic: Diagnosed ENTIRE audio chain.  (Read 2549 times)
« on: Sat, 16 April 2022, 16:19:47 »
Computer, sound card, cpu, mobo, the piano, cables, subs, disassembled speaker crossover to verify component tolerances.
Turns out it was just a loose cone... took all day....
Went in exactly the wrong order.
Offline Faceman76
Re: Diagnosed ENTIRE audio chain.
« Reply #1 on: Sat, 16 April 2022, 16:24:18 »
How does a cone become loose?
Sent from my SM-S908U using Tapatalk
1800s and heavy springs
« Reply #2 on: Sat, 16 April 2022, 17:21:44 »
Probably over time the wood expands and contracts from humidity, years of it can loosen the screw holding the cone. Cones actually have quite alot of mass.
Offline Faceman76
« Reply #3 on: Sat, 16 April 2022, 17:36:30 »
Ah, you mean the woofer's frame was loose.  Depending on your climate, if you have AC or not, I can see how screws may loosen over time.  Fortunately, I haven't had this issue.
Offline Darthbaggins
  • PC Cannibal
« Reply #4 on: Mon, 18 April 2022, 06:18:32 »
Also, I would see the vibrations over time would loosen the screws.  I would have checked the woofer/speaker first.
« Reply #5 on: Mon, 18 April 2022, 07:14:21 »
