Author Topic: Quite a stupid question i still want to ask about O-Rings.  (Read 7587 times)
Offline Nerif
« on: Mon, 29 August 2022, 10:59:20 »
Hello everyone. I've been using an Anne Pro 2 keyboard with Kailh Box Dark Yellow switches for two months. Also (if that matters), I've clipped and re-lubed the stabilizers and ordered some artisan keycaps (I'll show that two weeks later maybe), and I want to silence this keyboard a bit. The thing is, the downstroke sound gets annoying for me from time to time, so I'm about to buy some O-Rings. But, since the Kailh Box stem is quite different, I don't really know will the orings fit or not. Will the O-rings dampen the sound on Kailh box switches or not? Which thickness will be better for them?
Thanks for all of you in advance.
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
Offline Nerif
Re: Quite a stupid question i still want to ask about O-Rings.
« Reply #1 on: Mon, 29 August 2022, 11:01:52 »
By the way, for everyone who would ask "Why you just don't buy them, they're dirt cheap?" I would say that I really don't want to wait them to arrive if they're useless in my case.
Offline Nerif
« Reply #3 on: Tue, 30 August 2022, 07:52:50 »
tie a rubber band around it, see if it works.
ok, now i guess that 1.5mm orings will fit while the 2.5 ones wouldn't. Thanks.
« Reply #4 on: Tue, 30 August 2022, 08:37:12 »
I don't usually use Cherry-style switches, but my son, the gamer, does. He (and I) recommend the thinnest, softest o-rings you can find.
- D Trump 2026-10-24
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #5 on: Thu, 08 September 2022, 21:54:39 »
someone once made these thin foam squares with holes in the center obviously for the stem and they were fantastic. Haven't seen them in years though...
Edit: heres what i was looking for https://next.wooting.io/post/sound-dampen-your-mechanical-keyboard-noises  'Reaper' on here made them
-Dana
« Reply #6 on: Fri, 09 September 2022, 08:18:59 »
"Landing pads" are a more mushy feel but are better at sound dampening. If you can't find them store-bought they are not hard to make.
Offline ArchDill
« Reply #7 on: Fri, 09 September 2022, 08:29:54 »
I mainly use my hhkb nowadays but for the MX board I do use at work, I put some o-rings for the sake of sound. They for sure serve a purpose and are worth having around.
On all of my MX boards in the past, I have always stuck a really think o-ring on my spacebar. I can not stand a noisy space bar. My hhkb has bumpons under it so it will not be too loud
Offline granola bar enthusiast
« Reply #8 on: Fri, 09 September 2022, 12:44:15 »
BOOBS!!!!!11!
Offline Polymer
« Reply #9 on: Mon, 12 September 2022, 15:31:28 »
This...it changes the travel which you may or may not like....
Longer term..get different switches with dampening...
Offline Nerif
« Reply #10 on: Tue, 20 September 2022, 14:46:27 »
I guess I'll buy/build a keyboard with heavy linear silent switches after some time, but now I'm using a keyboard which I really enjoy to type on so I really want to improve it as much as I can.
Offline Nerif
« Reply #11 on: Tue, 20 September 2022, 14:47:22 »
BOOBS!!!!!11!
truly the best thing I've ever read here.
