Author Topic: DIY faraday cage or buy?  (Read 2542 times)
Offline Naweo
« on: Sat, 10 September 2022, 04:03:53 »
Hello, I want to get a pretty big faraday cage to store memory cards, hard drives, ledgers etc.
Anyone got knowledge and/or experience with this?
Re: DIY faraday cage or buy?
« Reply #1 on: Sat, 10 September 2022, 07:12:06 »
In most cases, a major CME won't fry those.  And if it fries the grid, none of that stuff would be useful anyway.
The apocalypse is not survivable, it's not possible with all the Nvk waste sitting around.  it would be a miserable few extra months/years at best.
Offline Naweo
« Reply #2 on: Sat, 10 September 2022, 08:15:40 »
Good to know, so it's a waste of time.
Thanks
Offline yui
« Reply #3 on: Mon, 12 September 2022, 14:09:28 »
if it is to protect them from the EMP from a nuke, or other world ending events, then it is useless, your ledgers will have no value without internet, and your other data will only have value if you survive and you have something to read them, if it is to protect it from your own high voltage experiments, i would put the experiment in the cage, not the drives etc. but either way a big metal box is a Faraday cage, if you want to make it out of mesh the thinner the holes in the mesh the higher the frequency it will be able to block fully, for a tesla coil you would want rather thin stuff, you want smaller than the wavelength you want to block optimally, that is if i remember right, those lessons were a long time ago and never used since then :)
given what you want to put inside, an old computer case with no glass panels would make for a decent faraday cage, it is already meant to keep the EM interferences from the inside of the case from interfering with things outside. you can plug the psu hole with aluminum tape to make it extra safe if you want.
« Reply #4 on: Mon, 12 September 2022, 14:24:03 »
If you want to protect a spinning-rust harddrive against magnets, the only sure way is to store it in a sealed box of a ferromagnetic metal (steel) — the thicker-walled the better.
