Author Topic: USB-C - the new EU standard ?  (Read 16561 times)
« on: Fri, 07 October 2022, 15:56:19 »
Everybody wants fewer cables and chargers, and so does the environment.
I can say that personally, I appreciate that my current desktop computer (2020) uses the same power cable that every desktop that I have had since the 1980s has used - although I have a basket full of them now, possibly dozens of them, gathering dust.
Did the EU get it right by choosing USB-C?
And will the idiosyncrasies in its implementation (direct and indirect) sabotage many of the possible positive outcomes?
https://www.business-standard.com/article/technology/eu-rules-what-makes-the-usb-c-port-the-gold-standard-of-charging-ports-122100600105_1.html
« Last Edit: Fri, 07 October 2022, 17:33:27 by fohat.digs »
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Offline Leslieann
Re: USB-C - the new EU standard ?
« Reply #1 on: Fri, 07 October 2022, 22:43:28 »
Heard more than a few Apple fans complain.. "We have to replace all of our cables now!"
My thoughts,
And? You were going to have to replace them again soon anyhow given how fragile the Lightning cables are, at least now you can get a cheap cable that will last 5x longer.
Apple sells cables like HP does printer ink.
You buy the printer, it runs out of ink, you buy ink, plus extra ink. Then the printer dies but you have more money in spare ink than you have invested in the printer so you buy the same printer again. I cannot tell you how many HP printer owners I see who do this, between ink, familiarity and the software "I don't want to have to reinstall everything again!", they just keep buying the same garbage.
It's the sunk cost fallacy and both HP and Apple know it very well.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Online tp4tissue
« Reply #2 on: Sat, 08 October 2022, 09:50:21 »
yup, same with joystick drift,   they knew the whole time,  support the Kong controllers.
« Reply #3 on: Sun, 09 October 2022, 02:56:49 »
Surely a standard has to be semi permanent to have a significant impact, USB micro had what, 5 years?
* suicidal_orange checks
10 years.  Ok that's not so bad.
Even ignoring the dodgy implementation options you have to wonder if it will it be illegal to bundle a cable with everything?  If not all the big manufacturers still will (reviews complain the "bundle" is lacking if they don't) and it will make no difference environmentally speaking.
Online tp4tissue
« Reply #4 on: Sun, 09 October 2022, 09:46:08 »
do we actually get more insertion on usbc or is that theoretical only
Offline Leslieann
« Reply #5 on: Sun, 09 October 2022, 13:32:08 »
I searched and couldn't find a rating from Apple, C should be at the very least equally as long lived.
Doesn't actually matter?
Even if the Lightning cable has a similar insertion rate, Type C is at least as long lived at a fraction of the price, available everywhere, and you can get cables that will last MUCH longer.
Lightning's well past it's prime (USB 2.0 speeds and power), it's proprietary, highly prone to failure (at the cable connection and the connector itself) and because it requires an Apple chip inside, it's expensive by comparison.
It should have been retired the same year Apple went all Type-C on their laptops.
Which brings up another important point, since when are Apple people suddenly concerned about Apple changing standards? I think most of the hate is less about changing away from Lightning and more to do with Apple people no longer being special.
« Last Edit: Sun, 09 October 2022, 13:34:56 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Darthbaggins
  • PC Cannibal
« Reply #6 on: Mon, 10 October 2022, 09:47:34 »
Knowing Apple, their retort to this will be no charging port and wireless/MagSafe charging only so they don't have to give into the EU.  I'm with LA on Apple should have changed the standard back in 2015/16 when the MacBooks went to TB 3/Type C format for charging (and have remained at that standard).  I despise the lightning connector, as having to remove a broken one from a port since the cable end failed - not fun, but the iPad Air it broke-off into still works and the internal port was good.
Offline Leslieann
« Reply #7 on: Mon, 10 October 2022, 13:03:43 »
Exactly what I expect to happen.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
  • PC Cannibal
« Reply #8 on: Wed, 12 October 2022, 11:21:39 »
We all know they have been teasing a port-less device, just never had said when they would launch it - I was expecting it to be the iPhone 14, but guessing just not yet and the EU's push will move this ahead faster now
Offline Telstar
« Reply #9 on: Mon, 17 October 2022, 15:31:06 »
Non-apple braided cables are cheap and awesome. I will have to replace two of them, 20 bucks, but I'm still happy with the idea of a universal standard for charging devices (not just phones).
Micro USB was awful. Lightning was ok but usbc is too.
Offline SBJ
  • Tactile pls
« Reply #10 on: Mon, 17 October 2022, 15:59:49 »
Been wireless charing myself since december I think. It's okay, and I guess it is less wear and tear on the port.
Offline Leslieann
« Reply #11 on: Mon, 17 October 2022, 21:02:27 »
Yep, probably 3 years in my case (3 years home, 1 in my car).
Love it.
Get a dock, not just a pad/puck.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline thocciness
« Reply #12 on: Thu, 17 November 2022, 10:46:44 »
I wonder if this will allow new ports to develop in the future when something faster/more powerful comes in
Offline TacticalCoder
« Reply #13 on: Mon, 19 December 2022, 13:58:20 »
The big problem with USB-C is that it's not a standard but countless standards with the same form factor.  You can have different cables with different things supported and now even hubs with seemingly identical USB-C ports but which are different in functionality (for example the one for receiving the charger cable is different than the others).
So: physically the exact same cables *and* ports but all with different functionalities.  You now need to pay attention to which cable you plug where: it all fits but that's about it. That's not exactly great.
Then there are gotchas with the pass-trough too: say you hook two stuff with a USB-C cable and get very fast tx speed, that's great.  But then you plug the USB-C cable to your monitor's USB-C port and then an external SSD to your monitor's USB hub and, boom, performance degraded to 2.0 speed or something as if the 2000s called.
But I do like it's form-factor and you can plug it upside down so that's convenient.
And the coming specs are insanely fast: USB4 gen 3x2 does 40 Gbps and has a data transfer mode.
So mixed feelings: amazing form factor, potentially great speeds coming but soooo many gotchas with the cables / ports / version of the standard/protocol supported.
Online tp4tissue
« Reply #14 on: Mon, 19 December 2022, 17:41:30 »
the great speed is only with an insanely thick cable + expensive, or a super short one, so yea it's cool, but still somewhat limited.
