Author Topic: sum'n'sup  (Read 3624 times)
sum'n'sup
« on: Fri, 16 December 2022, 13:18:07 »
w' sulfates.  SLS
Yall notice the toothpaste and shampoo are both significantly "LESS" bubbly than they used to be ?
Tp4 uses dat pantene and colgate,  recent batches are much less lather-y,  they've clearly reduced the bubble chem.
Offline Darthbaggins
  • PC Cannibal
Re: sum'n'sup
« Reply #1 on: Fri, 16 December 2022, 14:24:36 »
or diluted them more and raised the price.
Offline pixelpusher
Re: sum'n'sup
« Reply #2 on: Fri, 16 December 2022, 15:30:52 »
w' sulfates.  SLS
I've noticed with shampoo, but not toothpaste.  Maybe it's brand specific.  I use Crest and Pantene
Re: sum'n'sup
« Reply #3 on: Fri, 16 December 2022, 16:23:58 »
My coworker brushes with concentrated charcoal. You'd think that to be counterproductive.
Offline iLLucionist
  • Topre is Love.
Re: sum'n'sup
« Reply #4 on: Tue, 20 December 2022, 06:30:40 »
hey tp, been a while, still dominating offtopic i see
Re: sum'n'sup
« Reply #5 on: Tue, 20 December 2022, 09:55:21 »
we are 1, join us
