Author Topic: Salt  (Read 6155 times)
Salt
« on: Sat, 28 January 2023, 10:34:13 »
You guys ever eat so much salt in 1 meal, and think, oh god, I think I'm having heart palpitations..
new batch of pickled gai-vegetable just finished, ate about a fist full.
Re: Salt
« Reply #1 on: Sat, 28 January 2023, 10:51:10 »
Water + Potassium
- D Trump 2026-10-24
Re: Salt
« Reply #2 on: Sat, 28 January 2023, 15:42:55 »
isn't potassium also usually in the form of salt ?
Offline PlayBox
Re: Salt
« Reply #3 on: Sat, 28 January 2023, 15:44:30 »
that's a lot of salt to eat
propably sent from my amazon kindle 10th gen
Re: Salt
« Reply #4 on: Sat, 28 January 2023, 15:57:14 »
Table salt is sodium chloride. Sea salt is better but not the entire solution.
The body needs both sodium and potassium in roughly equivalent amounts, but we tend to get much more sodium than potassium in modern diets.
https://www.youtube.com/watch?v=z4MFnrMpzBA
Offline PlayBox
Re: Salt
« Reply #5 on: Sat, 28 January 2023, 16:00:32 »
solution: consume banana
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Salt
« Reply #6 on: Sun, 29 January 2023, 05:04:04 »
Water + Potassium
Exactly, or low-sodium salt. That's already got the proportions adjusted to compensate.
Offline phinix
Re: Salt
« Reply #7 on: Mon, 30 January 2023, 03:13:55 »
When we are in the subject of salt and its unhealthyness, which salt do you guys use for your cooking?
Which low-sodium would you suggest?
I've read that Himalayan pink salt is better. Are there better options?
Offline chyros
  • a.k.a. Thomas
Re: Salt
« Reply #8 on: Mon, 30 January 2023, 03:57:18 »
Why on Earth would you say that? Oo
Re: Salt
« Reply #9 on: Mon, 30 January 2023, 08:41:13 »
I read that too. The impurities that make it pink will obviously change the flavor and nutrition profiles.
Bought some and it is very good, but I don't use it because it has (a very small amount of) grit in it that is unpleasant when I chomp down on it.
Offline chyros
  • a.k.a. Thomas
Re: Salt
« Reply #10 on: Mon, 30 January 2023, 10:13:23 »
Well sure, but what is "better"? Tastier, healthier, makes for easier cooking, etc? In any case, all your're doing is adding trace impurities to your dish. The amounts are so low that it'd be difficult to defend a genuinely noticeable effect, I think. You may as well just sprinkle some rust into your dish and save on expensive salt.
Offline phinix
Re: Salt
« Reply #11 on: Mon, 30 January 2023, 10:37:57 »
Based on sodium levels compared to regular table salt.
Table salt contains 2360 milligrams of sodium per teaspoon, whereas a teaspoon of Himalayan pink salt contains 1680 milligrams of sodium.
That is what I've read.
Offline phinix
Re: Salt
« Reply #12 on: Mon, 30 January 2023, 10:38:57 »
I have no idea, if its tastier, never used it.
Offline chyros
  • a.k.a. Thomas
Re: Salt
« Reply #13 on: Mon, 30 January 2023, 11:07:16 »
That sounds like it's had potassium added to it, frankly. In any case, it's the same sodium reduction as what you get with ordinary low-sodium salt; no magic pinkness needed.
Re: Salt
« Reply #14 on: Mon, 30 January 2023, 11:26:23 »
no magic pinkness
My Himalayan salt is very coarse, whereas table salt is fine, so the overall product mass of a spoonful might be less.
I once visited Hawaii and was surprised to see dramatically different colors of sand beaches, one quite orange-red, another very black, etc, I was startled to see anything outside the narrow beige-to-tan spectrum that I was accustomed to.
Significant chemical differences from place to place seem pretty natural.
Offline ArchDill
Re: Salt
« Reply #15 on: Mon, 30 January 2023, 14:24:16 »
I like to have a side of food with my serving of salt.
