Author Topic: HHKB domes have become heavier overtime  (Read 7458 times)
Offline Auslander
« on: Tue, 31 January 2023, 19:32:08 »
I've been using my HHKB JP for a while as my daily driver and i have two new in box ones and they are much lighter than the one i've been using, sometimes i notice the extra weight is giving me a slight amount of fatigue and if i switch to one of the unused HHKBs the fatigue is gone.  I bought all 3 HHKB's at the same time and they all felt the same so im certain the one that is my daily driver has just stiffened up a bit over time.  I have a pack of Deskeys silencing rings that are standard thickness, would using those to reduce the travel help to reduce some of the weight?
The Topre domes get stiffer over time due to drying out from use right? Is there such thing as a lube for the dome sheet that could perhaps alleviate this?
HHKB JP | Realforce 104UB-DK | HHKB Pro 2
Offline Nerif
Re: HHKB domes have become heavier overtime
« Reply #1 on: Thu, 02 February 2023, 10:29:05 »
This thing happens with ALL switches based on rubber domes, and Topre is not an exception, at least as far as I know.
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
« Reply #2 on: Thu, 02 February 2023, 18:20:52 »
yup, and give it enough time, they might even crack.
Offline PlayBox
« Reply #3 on: Mon, 06 February 2023, 14:44:31 »
wait tp4 is on topic?
propably sent from my amazon kindle 10th gen
Offline tricheboars
  • Keyboards are Important!
« Reply #4 on: Tue, 07 February 2023, 08:48:50 »
some people try and collect aged topre as they like it better. personally 45g topre is about as heavy as i like.
Offline Nuap
« Reply #5 on: Tue, 07 February 2023, 16:47:57 »
It happens with Topre.
I replaced my >10 year old domes with Deskeys BKE Domes because they were too heavy (they didn't go to waste, they're now with an aged dome enthusiast).
Offline invariance
  • ...here with all the other boson's
« Reply #6 on: Fri, 10 February 2023, 02:17:29 »
Is this an enthusiast into aged domes or an aged enthusiast into domes?  :))
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
