Author Topic: PM2.5 to Cigarettes [Pollution Calculator]  (Read 13294 times)
« on: Sun, 18 June 2023, 20:33:40 »
Very cool that you can download Historical AQI database from AQICN.org as CSV
This means you can calculate for example, across 10 years, how many cigarettes Equivalent you've smoked as the result of Air pollution (pm2.5 concentration).
22ug/m^3 a day is equivalent to 1 cigarette worth of overall Life expectancy health risk.
The data is in AQI, so you convert it back to ug/m^3, and divide by 22.
For example: counting from 2014:
New Delhi, India,  ___ 13208 cigs, 660 packs, 4.4 cigs/day
Bakersfield, California, 2238 cigs, 112 packs, 0.65 cigs/day
New York City, ______ 1125 cigs, 56 packs, 0.35 cigs/day
Example Xlsx included:
You can copy Function from Column H onward to any csv data downloaded from AQICN.org
If value returns #value, you need to delete empty rows at end of data
If value returns div/0, you need to remove OR adjust AQI readings above 500, USA AQI calculation only goes up to 500.
Excuse the messy use of if statements, Tp4 not xpurt @ the xcel.
299927-0
299929-1
Re: PM2.5 to Cigarettes [Pollution Calculator]
« Reply #1 on: Mon, 19 June 2023, 09:17:41 »
Interesting, so at least we know china didn't lie about improving air quality in beijing,
Calculating the cigarettes smoked per year, clearly indicates a strong improvement
299937-0
« Reply #3 on: Mon, 19 June 2023, 09:38:19 »
Bakersfield and NYC
You can see from 2019, covid reduced PM, then sharp rebound during reopening.
nyc
299941-0
bake
299943-1
« Reply #4 on: Mon, 19 June 2023, 09:54:18 »
So, would breathing through an unlit cigarette act as a decent filter?
- D Trump 2026-10-24
« Reply #5 on: Mon, 19 June 2023, 10:39:39 »
test it fohat,  for science, can this be done?
those filters are actually extremely good filters in their own right.
« Reply #6 on: Mon, 19 June 2023, 11:42:46 »
okokok, something Fisshy going on in HOTAN... official sensors have been turned off since June 2020.
Bad airquality is mainly due to frequent dust storms, but industrial buildup is certainly an issue as well.
299947-0
« Reply #7 on: Tue, 20 June 2023, 06:11:25 »
This reads like a conspiracy... similar to how saudi arabia is never too hot for outdoor work, manipulation of weather reports to enforce unsafe slave working conditions.
The air quality data and information is subject to change at any time. AccuWeather has no legal liability or responsibility for the accuracy, completeness, or correctness of the air quality data and information, and expressly disclaims any and all damages or losses that may have occurred by you or any third party either directly or indirectly as a result of any information obtained from the air quality data and information. Reliance on any air quality data and information for any advice, including medical advice, is strictly prohibited. AccuWeather hereby disclaims any and all representations and warranties with respect to the air quality data and information, including but not limited to any implied warranties of accuracy, fitness for use, and merchantability. All air quality data and information is further subject to Plume Labs' General Terms and Conditions located here.
« Reply #8 on: Wed, 21 June 2023, 09:13:41 »
Observation:
So it seems AQI can still be great while the sky goes grey,  it seems smoke has a ground clearance attribute. It can be high up and block sky, without percolating in high pm2.5 at ground level.
« Reply #9 on: Mon, 26 June 2023, 05:48:31 »
Holy Heck..
Anything around and Above 500, means you are smoking 1 cigarette per hour.
300087-0
« Reply #11 on: Thu, 29 June 2023, 11:24:53 »
Airquality getting so bad,  the Airgov website is flooded...  Super slow, sometimes won't even load.
1/3 of the USA population ~120million people are under Air Quality Alert today.
« Reply #12 on: Thu, 29 June 2023, 16:16:27 »
Handy, quick conversion table.
For whatever reason, AQI isn't a straight line with PM2.5, which is why it looks crooked when calculating Cigarettes smoked Per day.
Download the xlsx in attachments below.
300317-0
« Reply #13 on: Fri, 30 June 2023, 13:52:55 »
It's pretty kewl that AQI goes into Code Red 151+ Code Purple 201+ Code Maroon 301+
What's today, Officially ? Code RED.  NICE !!
« Reply #14 on: Fri, 30 June 2023, 14:19:58 »
Interesting Equivalences:
3 People smoking in a typical sized restaurant = approx 600 pm2.5 count.
5 People smoking = 1200
20 People smoking = 5000
So..... If you think about why Boomers who grew up in "The Haze", are kinda messed up, bad decision makers, seemingly brain damaged.
Well...... /Pollution Perspective.
