Author Topic: Lunch Containers  (Read 6625 times)
Lunch Containers
« on: Thu, 24 August 2023, 16:47:15 »
Having some trouble with glass, the tops always get loose after a while, and it leaks, you can tie it up with something but that's not been the perfect solution.
Looking at metal, but it doesn't look like the designs seal any better, and if it bends, overtime, might get leaks too.
What do you guys use?
Offline Darthbaggins
  • PC Cannibal
Re: Lunch Containers
« Reply #1 on: Thu, 24 August 2023, 17:39:51 »
Ziplock twist-top containers are what I use and depending on what it is I might grab my Stanley Thermos.
« Reply #2 on: Fri, 25 August 2023, 01:58:58 »
I'm a huge fan of the dabbawala containers they use in India. They keep goopy Indian food from going all over, while being transported on horrible roads to hundreds of people a day, all by bike and moped.
If they make a smaller version of those, that is what I would use. You could huck it down a mountain and still have a good lunch.
Offline juliday
  • Synth, Controller, and Keyboard
    • SagakLabs
« Reply #3 on: Fri, 25 August 2023, 04:25:01 »
Japanese lunch boxes had some solutions I remember,
They are quite serious about the lunchboxes and they carry soup too.
Maybe looking up the amzn jp could help you?
Offline Coreda
« Reply #4 on: Wed, 30 August 2023, 03:15:34 »
Tiffin containers. Yeah, they're useful though my only critique is the base of each stack above the next will (obviously) get some of the contents of the stack below if shuffled about too much, though if there's enough headroom between it's not an issue.
« Reply #5 on: Wed, 30 August 2023, 06:11:36 »
It boggles the mind that in 2023, collective humanity has NOT mastered the lunch-box.
« Reply #6 on: Wed, 30 August 2023, 10:12:22 »
In my opinion, these are the best although they are heavy and expensive.
For the cheaper and lighter option, I also prefer the Ziplock screw-tops.
- D Trump 2026-10-24
« Reply #7 on: Wed, 30 August 2023, 13:05:38 »
The problem is the lid comes loose after a while and they start leaking. If you refrigerate, those flaps also crack off eventually.
« Reply #8 on: Wed, 30 August 2023, 13:05:48 »
Don't wash the tops in the dishwasher at high temperature.
« Reply #9 on: Wed, 30 August 2023, 13:06:54 »
Tp4 can't afford to use the dish washer,  it's like 4 hours of electricity + hot water.
« Reply #10 on: Wed, 30 August 2023, 13:21:30 »
Flexing refrigerated plastic is never a good idea. I try to let it warm up to room temperature wehnever I can.
Offline kajahtaa
« Reply #11 on: Wed, 30 August 2023, 15:05:03 »
Find a tree. Eat a couple acorns. Weight loss ensues. No plastic needed.
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #12 on: Mon, 18 September 2023, 07:43:19 »
I just use a bag.
Usually I don't eat lunch though. My adderall makes me not want to eat.
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
