Author Topic: MPE-AXE3000H Review [Saving old laptops]  (Read 6822 times)
« on: Mon, 01 April 2024, 18:19:44 »
Just found out this card exists.
Early-Mid-2000s laptops, they used half height m-pcie wifi cards. The new M.2 NGFF form factor wifi cards do not fit, like the Intel AX200-AX210, or Any of the AC8000 series.
Enter  AXE3000H,  It's an off brand m-pcie form factor card with an official intel AX210 Chip, that just fits.
So, all the popular Early-Mid 2000s laptops can upgrade to WIFI AC/AX.
Card works amazing. 100Megabyte/s in AX-mode on Thinkpad X220, nearly as good as wired.
Grey antenna to 1, Black antenna to Aux.  (Blue/Red) antenna are for wwan, they're tuned for different frequencies, they do work but sub-optimal transmission, do not use.
You require the mod-bios to get bluetooth working (thinkpads), as it requires enabling the usb port on the m-pcie slot.  If you don't need the updated bluetooth 5.3 on the new AX210, the original bluetooth daughter board goes up to Bluetooth 4 and work just fine.
An incredibly conveniant card, plug and play, Loads official Intel Drivers, lots of legs left on old laptops. Internet as a whole is much smoother/ lower latency than older cards like 6300 ultimate-n (~23MB/s max).
Re: MPE-AXE3000H Review [Saving old laptops]
« Reply #1 on: Thu, 04 April 2024, 18:55:18 »
Probably placebo, but the laptop feeeels faster w/ the new wifi card. Would a webpage load fractionally faster with ~3x the bandwidth.
« Reply #2 on: Fri, 04 October 2024, 09:58:57 »
Cowurk guy's brand new dell with cheapie wifi card 200mbps,
Tp4 wrecks him on 13yr old x220 w/ 600mbps.
