Author Topic: Soft Rim is best !!  (Read 4451 times)
Soft Rim is best !!
« on: Thu, 09 May 2024, 15:05:34 »
What say Gekha ?
307819-0
Offline Rhienfo
  • GOTHETIGES
Re: Soft Rim is best !!
« Reply #1 on: Sat, 11 May 2024, 08:15:27 »
I've never really use these trackpads on laptops. Why do people use them and why do you think the soft rim one is the best, not sure how there would be a noticeable difference between them.
« Reply #2 on: Sat, 11 May 2024, 14:29:04 »
They are very convenient, and I think they are faster and simpler than track pads. But I mine has the usual dome and I don't think I have tried any others.
- D Trump 2026-10-24
« Reply #3 on: Sat, 11 May 2024, 19:58:55 »
The rim one is much easier to hold down while scrolling, The dome one is good, but your finger slides off if you hold it down.
