Author Topic: Pixel fone.  (Read 4846 times)
Pixel fone.
« on: Sun, 19 May 2024, 10:17:10 »
Just got a pixel fone, man guys, these things are kinda invasive. It's digging into your mind and trying to connect you to the matrix.
Was having trouble with the unlock (fingerprint), and after a bit, it sends you an alert, having trouble with the fingerprint scanner, try adding your face for face unlock.
This thing is measuring and monitoring everything.
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: Pixel fone.
« Reply #1 on: Sun, 19 May 2024, 10:21:09 »
I didn't have to put my fingerprint or face id on my pixel, Just a passcode. I generally don't put those things on them, but that's superstition on my part, since both fingerprint and face id are both stored locally on the device from what I know, so they can't access that data remotely.
Putting my comment from what's bothering you here as well.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Re: Pixel fone.
« Reply #2 on: Sun, 19 May 2024, 10:22:42 »
It's not that I'm worried about adding the biometrics, it's that I'm actively being monitored to such extent.
Offline Rhienfo
Re: Pixel fone.
« Reply #3 on: Sun, 19 May 2024, 10:29:24 »
It's not that I'm worried about adding the biometrics, it's that I'm actively being monitored to such extent. [/size][/color]
ah true didn't see that. I don't think I got any notifications that seemed like they were monitoring what I did, Just the standard stuff like notifying for security updates and like telling you to backup photos. Maybe it's because I didn't put the biometrics in. Wouldn't be surprised if google was monitoring people like that, they love that data.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Re: Pixel fone.
« Reply #4 on: Sun, 19 May 2024, 10:33:07 »
Then they flash these random privacy policies at you a few hours into usage, after the initial setup.
My guess is they hope you gloss over it, and never turned them off, just thinking they were part of some app.
Re: Pixel fone.
« Reply #5 on: Sun, 19 May 2024, 13:58:05 »
The hardware's decent enough. Can't complain. Everything's pretty light / smooth with stock android.
The launcher is, lets say you want to change brightness, you have to scroll down twice. Hrrrm..
Tp4 got the working-poor 8a edition, so the camera is meh. But Tp4 takes very few photos.
Screen quality, You know good and bad. It's very accurate, you can tell they're clamping the gamut hard. The draw back is, everything looks a bit dull like on ifones, they do the same thing, target accuracy. Samsung has that rainbow barf color mode, which Tp4 embarrassed to say enjoys on mobile.
Accuracy is not better in the majority of cases outside of photo apps.
Re: Pixel fone.
« Reply #6 on: Sun, 19 May 2024, 14:07:17 »
The first party app icons. /frowny face.
Offline Rhienfo
Re: Pixel fone.
« Reply #7 on: Sun, 19 May 2024, 21:53:33 »
I think what you get with these phones is great for their price especially the a variants, the only real subpar thing is the cameras, wish they would be a little better but for what I paid I can't really complain.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Re: Pixel fone.
« Reply #8 on: Sun, 19 May 2024, 23:33:14 »
Tp4 went pixel for android to avoid samsun's slow/never software updates.
The China fones look pretty nice, but their support is even worse than samsun.
But the pixel generates in Tp4 a deep seated unease about joining the google-sphere so intimately.
Re: Pixel fone.
« Reply #9 on: Sun, 19 May 2024, 23:56:34 »
the s24 has the fastest gpu on the market i think?
Re: Pixel fone.
« Reply #10 on: Mon, 20 May 2024, 04:43:54 »
It does, but Tp4 does not play games or watch movies on fone, it's pure torture for Tp4 relative to his proper-equipment.
Re: Pixel fone.
« Reply #11 on: Mon, 20 May 2024, 11:03:32 »
One thing about the 8a, in a case, it looks drab and stealth, all them phone stealers prolly out for ifones, wouldn't even bother with the 8a.
Tp4 has 2 wurk ifones, feel free to stealz that, less wurk 4Tp
Re: Pixel fone.
« Reply #12 on: Mon, 20 May 2024, 18:22:54 »
Taking back what Tp4 said about the camera.
Gotten used to weird cameras on other fones, including ifone (everything is too green).
The 8a camera is fairly natural and realistic, although this does make it less fun of a photo compared to Samsungs which just ignore reality altogether on color.
Re: Pixel fone.
« Reply #13 on: Thu, 23 May 2024, 22:02:40 »
IDK why there are so many negative reviews on the Pixel's battery performance.
Been using it on the road. Very well maintained, nearly no perceptible idle power draw.
Maybe written by apple bots.
Offline Rhienfo
Re: Pixel fone.
« Reply #14 on: Thu, 23 May 2024, 22:15:13 »
the battery has been fine for me too, maybe it's about the battery over a long period of time.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Re: Pixel fone.
« Reply #15 on: Fri, 24 May 2024, 08:29:54 »
I have had my Pixel 3 for at least 5 years and it has served me quite well. Also the battery still holds quite a decent charge.
Always careful with it, and always keeping it in a good case with a screen skin, it still looks and works great. There are numerous behaviors that perplex me, but they are probably my own fault or ignorance. Fortunately I have two 20-something kids (we all got these phones at the same time but they have long since moved on) and they can help me out.
I do wish that the fingerprint reader worked better, but I am old and my fingerprints have become pretty faint after decades of wear and tear.
From the US Constitution, Article 1, Section 8 :
The   Congress   shall have Power
To declare War,  grant Letters of Marque and Reprisal, and make Rules concerning Captures on Land and Water;
To provide for calling forth the Militia  to execute the Laws of the Union, suppress Insurrections and repel Invasions;
Re: Pixel fone.
« Reply #16 on: Fri, 24 May 2024, 09:48:50 »
The fingerprint sensor is just bad, it's not your fingers.
You have to do 1 fingerprint,  then when your finger gets dry or wet, you do another one at the time where it doesn't work.
That way the sensor can read all  WETNESS levels of your finger.  It's ridiculous. Isn't technology wonderful.
Offline Rhienfo
Re: Pixel fone.
« Reply #17 on: Fri, 24 May 2024, 09:54:45 »
I've found it weird that the fingerprint is on the screen, apart from my previous phone I used to use devices that had the fingerprint scan on the home button, and those seemed to work no matter what the condition of your phone. Maybe that would make it better, but the more time has past the more I realize that the home button isn't as intuitive to me as swipe gestures. Still, seeing touch unlock work without that button still is strange to me.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Re: Pixel fone.
« Reply #18 on: Fri, 24 May 2024, 13:06:23 »
That would be nice. On the 3 it is on the back.
Re: Pixel fone.
« Reply #19 on: Sat, 25 May 2024, 00:06:35 »
Bough dat anker space a40 on a whim based on rting review. The noise isolation is incredible. Thought it was gonna be LIES, but no, it actually works way good'er than most NC earbuds I've tried.
Offline Rhienfo
Re: Pixel fone.
« Reply #20 on: Sat, 25 May 2024, 03:18:08 »
Oh didn't know it's on the back on the 3, that's pretty weird, I guess the technology wasn't developed at the 3 and just thought it was the better idea at the time.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Re: Pixel fone.
« Reply #21 on: Sat, 25 May 2024, 11:31:35 »
You no, m0ar the Tp4 thinks about this,  the crappier the fingerprint reader is, the more secure, because if it can't read your fingers, it sure as heck won't read anyone else's.
It's a -Feature. Pixel Security #1
That doesn't look like your finger,  why don't you rub it on a towel for 5 minutes and come back.
