Author Topic: Listening Standing  (Read 4576 times)
Online tp4tissue
Listening Standing
« on: Fri, 26 July 2024, 08:44:30 »
Recently ran some calibrations for standing position. Noticed that you can feel more of the bass because the "butt + back" area is not dampened by the chair.
Thoughts? NE1 music standing up?
Offline Sniping
Re: Listening Standing
« Reply #1 on: Thu, 01 August 2024, 12:21:01 »
I believe it's because low frequencies are less directional. when you're standing, the midrange driver and tweeter usually is pointed below you depending on how things are angled. btw, you should check out open baffle diy speakers if you're looking to do some tinkering with stereo setups.
Online tp4tissue
« Reply #2 on: Thu, 01 August 2024, 13:07:57 »
Is open baffle very expensive to drive to get low bass? It looks like they'd need alot of power to move very big cones without port effect to support the dip.
