Author Topic: Ne1 try dat Potassium Chloride?  (Read 4989 times)
« on: Tue, 17 September 2024, 12:17:13 »
Substitute for Sodium Chloride (NaCl).
S' fine?  Didn't die?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Ne1 try dat Potassium Chloride?
« Reply #1 on: Tue, 17 September 2024, 12:59:13 »
Been using it for years, it's fine. It's 2/3rds NaCl anyway.
« Reply #2 on: Tue, 17 September 2024, 13:13:06 »
What if you get dat 100% K Cl ?
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Tue, 17 September 2024, 15:55:25 »
Not sure anyone sells that Oo . That might be toxic, given the way the Na/K balance is fundamental to your body operating.
« Reply #4 on: Thu, 19 September 2024, 09:34:23 »
Got the 2lb bag.
Pretty spensive,  but,  figure if it works fine, Tp4 can get it from tractor supply brine tank version, which is wayyyyyy cheaper.
It's 100% KCl
Internet says it's safe to replace NaCl as long as you don't have kidney problems or take certain medication.
Taste,  not as salty as salt, maybe 80%-ish, has a slight bitter aftertaste,  definitely can't notice the aftertaste in a stir fry, but it's there.
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Thu, 19 September 2024, 11:43:21 »
Got the 2lb bag.
It's 100% KCl
The taste is another reason most low-Na salts are only partly KCl.
Might interest to know you that KCl is the chemical they use to kill you with lethal injections :p .
« Reply #6 on: Thu, 19 September 2024, 11:45:46 »
Finally , sweet release from this horrid timeline.
« Reply #7 on: Fri, 20 September 2024, 08:12:56 »
Day 2,  Feels a little lighter. Less tight.
« Reply #8 on: Fri, 20 September 2024, 20:14:51 »
I think people, Americans especially, tend to way oversalt their food. I only use salt as a prep ingredient, never add more to completed dishes because it is already salted. There should be zero reason for you to reach for the salt at a restaurant, or for a premade meal. Just use less salt. It is not hard to do.
