Author Topic: Does slow internet = virus load ?  (Read 4163 times)
« on: Sat, 28 September 2024, 13:57:48 »
My internet has slowed down dramatically in the last few days. I am on AT&T fiber and use Linux Mint OS.
During the decades I used Windows there were numerous free (and very easy to use) virus checkers. Are there any for Linux that are free and easy?
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Offline Aethelberht
Re: Does slow internet = virus load ?
« Reply #1 on: Sat, 28 September 2024, 14:33:04 »
Interesting. . .
I'm better than all of you combined.
« Reply #2 on: Sat, 28 September 2024, 16:36:17 »
Well the virus can't infect all your devices all at once,  try the other devices, if they're just as slow, it's not a virus.
« Reply #3 on: Sat, 28 September 2024, 16:59:47 »
Probably the FBI throttling your connection to monitor your data
Offline Leslieann
« Reply #4 on: Mon, 30 September 2024, 04:24:35 »
When was the last time you reset your internet and pc? How old is your router/modem?
ClamAV, like other linux anti-virus are just looking for Windows viruses, the AV industry all operates the same using the same definitions and ways to identify viruses. You will need to check resources manually either through terminal or a gui resource monitor. Honestly though, my money is on a loaded up router/modem or a dying router/modem.
A majority of routers/access points are really only good for 1-3 years.
My general rule is for every $50 you spend you get 6-12 months, with Asus and Buffalo being the longer lasting, Netgear being mid, and most others being crap. I also push heavily for open source models/compatibility as they tend to be a bit more stable and if they fail to update you can install aftermarket firmware.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #5 on: Mon, 30 September 2024, 05:09:42 »
Could you explain this in further detail? I didn't know routers were like iPhones and degraded over time. Ours is about 4 years old, and in the last year I've noticed a slower connection, but attributed it to Comcast bull****.
For reference we have a Netgear Nighthawk, which was always the most reliable modem back when I was doing testing for online games.
« Reply #6 on: Mon, 30 September 2024, 09:05:50 »
Recently-ish ....
I think this recent problem was the result of Helene - I never lost power but there was a lot of stuff going on in the region.
« Reply #7 on: Mon, 30 September 2024, 10:01:31 »
Very few models get aftermarket support, pretty much only 1 or 2 from each brand.
The Asus 86u series are the best supported.  But it's not forever, kinda bummed Tp4's ac2900gt which is AC86u is getting end of life through merlin. Maybe official firmware will go longer, but no more merlin.
The AX86u still has ongoing though. So that's probably the best buy. Although it's pretty expensive and AX is useless to most people.
AX86-S goes for $140 used, these might be the best bang for buck.
Adding a FILTERED active fan is a must for these routers, they get incredibly hot, 80C+ in summers without fan.
Tp4 suspects most router die because of heat.
« Reply #8 on: Mon, 30 September 2024, 11:06:08 »
All the router talk this morning.
Checked the router temperature, haven't done that for at least a year, because who the hell checks their router temperatures all the time.
The temp was 75C on a cold morning. Woah, what's going on, Tp4 investigates.   The fan wasn't spinning because the 3pin connector wire pin had corroded, Damn, Guess should've direct soldered.
Lesson learned. Fan engaged, router cpu temp dropped from 75 to 56C.
Offline TomahawkLabs
« Reply #9 on: Mon, 30 September 2024, 11:22:35 »
Does anyone else here use Unifi devices?
I run their camera and networking gear. Camera app is very good. It's all PoE, so I have APs in the garage and on each floor. Everything else that can be is hardwired. I own the modem since I don't need the equipment from my ISP. All my camera feeds are locally stored and accessible via remote means, but I like the fact I own my footage and no corporate entity legally has rights to the footage. Not cheap, but the only devices I could see needing replacement would be the modem after DOCSIS 3.1 is no longer supported. The APs are all replaceable once Wifi 6 is considered old, but I don't understand how it would just stop working/supported in the near future.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
« Reply #10 on: Mon, 30 September 2024, 11:39:05 »
Just tested my max throughput with 1500 inbound connections, probably would never see a higher load than this outside of vpn. And this load itself is artificial, you just wouldn't use the internet like this.
Only 1 C increase on router with its cpu 25% loaded, from 56 to 57.
That kinda tells you this stupid cpu doesn't throttle down. Wasting precious electricity.
310208-1
Offline Leslieann
« Reply #11 on: Tue, 01 October 2024, 05:09:50 »
Very possible.
Usually what you see is either an unstable wifi signal (it goes up and down in signal strength), it can just run slow, or it can slow then completely just stop until you unplug and plug it back in clearing the memory. The latter is a classic failure over time, the bummer is it's hard for most people to figure out if it's the modem or the router that failed (if separate), just reset (unplug then plug in) the router first and if it consistently fixes the problem you have your answer, but it's almost always the router (99% of the time). Cable companies tend to do reliability testing on modems and companies are held to task on making sure they work well. Router companies, not so much if it's not enterprise grade. Surprisingly, even some of those are not really that great either.
Much of this is because a LOT or routers are not properly powered, the power system is designed to supply just enough juice for the cpu, nothing more (I.E. the switch, usb ports, etc...), over time the capacitors wear out and things go bad. They're probably outsourcing the design. Some include too small of a brick but others actually limit power internally for some reason. Some are also insufficiently cooled and some use cut rate internals. Then there is software, at least one major manufacturer does almost ZERO in house programming and instead farms it all out to India, they also have a history of pushing beta testing firmware onto customers, often with no way to revert to what sort of worked other than sending the customer a new device which is just dumb.
It's not easy for the average consumer to find out what brands, much less models are reliable, some of the most highly praised routers in history on launch were duds a year or two down the line regardless of cost. One simple rule I have found however is to make sure it has open source firmware, the companies making chips that can use open source firmware probably give better information on power requirements rather than some generic chip and they are usually using firmware built from a well known common base rather than programming tons of it from scratch and crossing their fingers.  This usually adds a a few dollars to the price and beware, some companies differentiate the open source models from closed source variants with a simple letter change so you need to be careful, but almost every closed source router I've used has had a short life span while almost every open source router I've used has lasted two to eight times as long. The companies I have seen do well repeatedly is Asus, Buffalo and TP-Link, even the closed source seem to work better than average.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #12 on: Tue, 01 October 2024, 09:48:39 »
The open source doesn't help if the community isn't large enough to fix the bugs. Only 2-3 models tops are popular per brand.
