Author Topic: OLED monitors  (Read 100819 times)
Offline phinix
OLED monitors
« on: Fri, 03 January 2025, 08:09:16 »
I can't find my previous OLED thread, so will start a new one.
I keep seeing announcements of those new OLED PC monitors, but they all are mostly 27" - who uses such small screens nowadays. I mean I would think that 32" is a minimum for OLED and 4K. Personally I think 40" is perfect, but we can only use OLED TVs and only get 42" ones (C4 or upcoming C5).
Why they still don't get us some nice, standard ratio (not those stupid ultra wides) 40" monitors?
I have 48CX but want to swap for C4 42" cause 99% of the time for desktop use, I keep windows smaller than full screen. When I had 40" Philips monitor years ago, that was pretty much sweet spot for me.
Re: OLED monitors
« Reply #1 on: Fri, 03 January 2025, 14:30:41 »
The small screens are alot more profitable. That's why the manufacturers are pushing them.
If you move the table back off the wall, and put the monitor Down a bit. That's the better way to use TVs.  Or use separate motor lift for the table and tv like Tp4 so you can sit and stand.
Offline Sniping
Re: OLED monitors
« Reply #2 on: Fri, 31 January 2025, 11:47:26 »
32 is actually quite on the large end for gaming monitors. the recent batch of oled monitors released last year were all 32" ones. they're quite good for mixed use but if you need bigger, you're out of luck unfortunately. the 32" models have a lot of good features like USB-C thunderbolt PD, built in KVM, and some have heatsinks to manage temperatures and prolong the life of the monitor. I personally use a 42 OLED. using a TV is certainly fine for browsing and some gaming but I totally see the appeal of the smaller displays that are purpose built for PC use.
Re: OLED monitors
« Reply #3 on: Fri, 31 January 2025, 13:37:17 »
The problem isn't the monitor, the problem is the space.
If we don't have a pc room to ourselves. Can't go bigger if the table has to be against the wall.
Tp4's main pc room is a small 10x10, but without bed or anything else, a motorized standing desk and motorized TV lift allows placement of the table at 1/3 from the wall. Now you can use up to 85ish inches at this distance. Or Up to 100inch if you want your back against the back wall.
Tp4 would argue 1/3 from front is better, because it gives you a little walking space while standing. Some times you do some kicks, get some range of motion.
Sitting for more than 3-4 hours is not healthy. Slowly destroying the spinal discs. Ask how Cripple-p4 knows? Sitting for 10-14 hours a day for 25 years.
Offline phinix
Re: OLED monitors
« Reply #4 on: Fri, 04 April 2025, 03:33:11 »
Just to say, after I got myself a C4 42" I feel like it is PERFECT monitor size. I had Philips 40" for years and wanted something bigger, so got myself 48" OLED. OLED is a top class of its own, so will never go back to VA/IPS, but the size - 48" was a waste of spacee for me for 80% of the time when I worked on it as I had all windows centered and maybe taking 70% of the screen. Now, with 42" it feels right, bigger a bit, good for gaming, but also good for work tasks.
Offline phinix
Re: OLED monitors
« Reply #5 on: Wed, 23 April 2025, 12:24:16 »
tp, do you know what color gamut do those LG C4 OLEDs have? I cannot find it in their specs...
I do some photo editing and was wondering - sRGB is standard, then my camera has Adobe, wider one - how does this correspond with OLED? 10bit, 12bit... I'm lost...
Re: OLED monitors
« Reply #6 on: Wed, 23 April 2025, 13:02:48 »
C4 at 200nits and lower is approximately 94% dcip3, if you run it at native gamut, where it looks its most saturated.
You can tell visually, just look at reds, if it looks "very red" it's native.  If it looks pinkish-or brownish, it's in a clamped mode, srgb like mode.
Srgb is the default internet standard, but it doesn't mean anything, if no one has a display matching those standards these days.
So, when you edit your photos,  you set photoshop for example to srgb, but what you see on screen is what you see on screen. Srgb is just the container's assumption. The device takes over from whatever the signal output is.
Most devices out in the wild now are Near P3 gamut, which is what the native output of the C4 will be.
If you edit your photos in a clamped srgb mode, it will look over-saturated when stretched to P3.
In reverse, if you edit in P3, and someone is viewing your photos on a monitor closer to srgb, it will look Under-saturated.
So it comes down to 2 things.  What are you trying to capture, and what is your intended target device.
Generally, the pros will use raw capture, then use a lut of some sort in the photo app for output and adjust for target device after the fact.
To keep it simple, make sure your LG is in its native gamut mode, check for saturation clipping using a pattern on your browser, and reduce the saturation setting on the LG until the clipping is gone.
Then when you edit the photo, check your work on a new lcd monitor, an old lcd monitor, finally an iphone.   That pretty much covers your audience.
Offline phinix
Re: OLED monitors
« Reply #7 on: Wed, 23 April 2025, 18:42:15 »
Yep, on native gamut - bright orange text on our GH site is burning my eyes :)
Re: OLED monitors
« Reply #8 on: Wed, 23 April 2025, 19:02:29 »
That means it's p3.
So you want to make your image just a bit oversaturated to compensate for people who might use an srgb system.
Check your work on multiple devices.
You don't need absolute accuracy unless you're Into that personally, or you have to color match a pipeline.
Offline YALE70
    • Hackjob
Re: OLED monitors
« Reply #9 on: Tue, 06 May 2025, 00:19:53 »
I picked up an old 16:10 ratio 30-inch Apple Cinema HD Display at the thrift store last week and am genuinely floored at how much more I like using this thing compared to the 34-inch Dell ultrawide I normally use on my main desktop. Obviously it's old as dirt and has it's share of issues, but it's got me tempted to pull the trigger on a new display with similar vertical real estate. Leaning towards a 32-inch 16:9 in either 1440p or 4K (preferably) with at least a 144Hz refresh rate, but tempted by the 38-inch ultrawides - but those are going to start pushing the limits of my current desk. Maybe even a 5K2K ultrawide? But those seem to be few and far between...
A TV seems like a great bang for the buck option too - getting a better panel and whole bunch of other bells and whistles for about the same amount of money as a 32-inch display; thanks to it being subsidized by all the pre-loaded data harvesting crap. But again, I'd probably be screwed on desk space with something that wide and without a proper stand (easy enough fix, but still). So many damn choices.
Offline Aljami25
Re: OLED monitors
« Reply #10 on: Fri, 03 October 2025, 09:47:16 »
Totally get you on that. 40 feels like the real sweet spot, but for now it seems like the only option is still going with the 42 OLED TVs like the C4/C5.
Re: OLED monitors
« Reply #11 on: Thu, 01 January 2026, 21:01:23 »
Looking into upgrading to a bigger and better monitor. 4K is useless for me since my hardware doesn't support it, so I'm considering this MSI monitor:
https://us-store.msi.com/Monitors/Gaming-Monitors/MPG-341CQPX-QD-OLED?utm_source=chatgpt.com
Anyone own one in this line?
Also considering this guy, since the price is so good. But I'm unsure of reliability(and it is VA):
https://www.newegg.com/hkc-cg345uk-34-wqhd-240-hz-va-black/p/N82E16824204015?item=N82E16824204015&source=region&utm_source=chatgpt.com
Offline Sniping
Re: OLED monitors
« Reply #12 on: Fri, 02 January 2026, 01:49:10 »
people dump 27" and 34" oled monitors used for like 300-400 bucks, or even less if you're a real deal hunter. it's a great value at that price so I'd recommend that. gigabyte m32u is also solid, has a built in kvm that works well and other good stuff.
Offline phinix
Re: OLED monitors
« Reply #13 on: Fri, 02 January 2026, 08:02:53 »
I'm waiting for 40" OLED monitors. 32" isnt enough for me personally. When it comes to pc gaming I prefer 40" estate.
For general use 32 is fine. However, for last 10 years I've been using 40, 48 and now 42", so maybe getting back to 32 wouldnt be bad, dont know...
Re: OLED monitors
« Reply #14 on: Fri, 06 March 2026, 12:20:58 »
There's no good reason to be < 77 Inches.
Offline phinix
Re: OLED monitors
« Reply #15 on: Fri, 06 March 2026, 18:52:01 »
77 is too much for me, I would have to sit like 2-3m away.
How you feeling tp?
Re: OLED monitors
« Reply #16 on: Fri, 06 March 2026, 19:51:09 »
How you feeling tp?
This is alrite, Tp4 has experienced all that life could offer, no regrats, god is kind, couldn't ask for better life lived.
The apocalypse is HERE.
Eatn' some microwaved totatoes right now, got a veggie cheese sauce, and ketchup, pretty gud'
Offline phinix
Re: OLED monitors
« Reply #17 on: Sat, 07 March 2026, 20:23:35 »
How you feeling tp?
Yeah yeah yeah... where were you for over two months tp?
Re: OLED monitors
« Reply #18 on: Sun, 08 March 2026, 04:29:00 »
They sent Tp4 to the Wall.  Tp4 do da't projected-project-cost, headquarters says too-high, then the War happened, EXTRA-Too-High, they send Tp4 back to bunker.
Offline Darthbaggins
  • PC Cannibal
Re: OLED monitors
« Reply #19 on: Sat, 25 April 2026, 22:44:31 »
Competitively game at anything above 27" in FPS titles and get back to me.
Re: OLED monitors
« Reply #20 on: Mon, 11 May 2026, 02:58:13 »
Who actually plays competitive gamz though?  Most of us only ever pretended to play e-sp0artz.  Pretend to Pretend.
77 Inch is the sweet spot for 10 feet rooms, with a good walking space standing desk.  85 inch is pushing it,  98 inch is you lean against the wall full time.
8K can't come soon enuff.
Offline phinix
Re: OLED monitors
« Reply #21 on: Mon, 11 May 2026, 07:16:29 »
but do we really need 8K?
I feel ike 4k is enough.
Re: OLED monitors
« Reply #22 on: Mon, 11 May 2026, 10:57:54 »
8K is quite interesting, because many old games can be played at that Res, and you get that ontop of great text clarity.
The issue right now is cable bandwidth is lacking to do Legit 8K.
We need a 272 Gbit cable for 8K, 10bit 240hz.  Unless we're willing to settle for DSC which is yucky. So we'd probably need fibr, or a cable with alot more pins.
Re: OLED monitors
« Reply #23 on: Mon, 18 May 2026, 15:09:42 »
There's no good reason why we don't have 4K 560hz. Yea, it requires DSC, but that's acceptable for the time being.
Re: OLED monitors
« Reply #24 on: Fri, 22 May 2026, 23:52:21 »
Minor, but relevant,
at 77 inches and above, Even at 17 nits, slides can be blindingly bright at night.
Offline phinix
Re: OLED monitors
« Reply #25 on: Sat, 23 May 2026, 14:16:34 »
Really? at 17? is it because theya re now really huge?
Re: OLED monitors
« Reply #26 on: Sat, 23 May 2026, 16:19:54 »
Yea, imagine 1 low brightness light,  but then you got a thousand of them.
Offline phinix
Re: OLED monitors
« Reply #27 on: Sat, 23 May 2026, 20:11:22 »
How far do you sit from it?
When you use Windows, do you keep taskbar on all the time?
Re: OLED monitors
« Reply #28 on: Sat, 23 May 2026, 20:51:50 »
Taskbar minimized.
The Top right buttons actually has high burnin risk. the minimize/maximize/close.
Set browser for auto-fullscreen
Offline phinix
Re: OLED monitors
« Reply #29 on: Mon, 22 June 2026, 18:59:27 »
tp, for PC windows (web browsing etc) - what do you set for white balance color temp - warm 50?
and for oled pixel brightness - I have 40.
For AMD card, I had to go and create custom resolution setting to have 144hz - is that right? As default it had 120Hz.
( I just updated my Windows to 11 and it messed up all my settings :( I have a feeling like fonts do not look so nice and sharp like they were on Windows 10)
« Last Edit: Mon, 22 June 2026, 19:05:56 by phinix »
Re: OLED monitors
« Reply #30 on: Mon, 22 June 2026, 19:07:27 »
Tp4 doesn't have C4, but warm 50 is close to 6500k, which is the standard.
You can go by eye on this, because your own eyes perceive color differently vs someone else.
If you look at a sheet of paper and compare your own 2 eyes, the color also changes.
