Author Topic: PC Sound Cards in 2025  (Read 53681 times)
« on: Thu, 12 June 2025, 21:13:37 »
With most people using integrated sound from their mobo, with many modern mobos having built-in amps and dac, is there any real point to using a slotted soundcard. All I can think of is if you're running a 7.1 setup and need the extra ports. Is the quality improvement noticeable? How do companies like Creative stay in business in 2025?
Re: PC Sound Cards in 2025
« Reply #1 on: Fri, 13 June 2025, 08:33:47 »
No there's no point.
Dac and Amp are solved problems. Unless they're defectively designed, which is rare these days, the freq response of the speaker + in room effect is 3 to 4 orders of magnitude more Distortion than what the Dac/Amp outputs.
The only thing relevant in terms of PC audio today is the Power Supply, where a bad one can dump hissing electrical noise into the motherboard.  This is typically not a design criteria, it's hit or miss if you go into the market place.  You can look for ones with the least ripple voltage, because it indicates competent design, it's not a guarantee.
You can get around this with optical out to a validated usb DAC on separate power. SU-1, unbalanced dac is the best value.
Fancier dacs, and going balanced is not worth it, it's entirely audiophile flexing, it makes no perceptible difference to sound, Because again, the distortion of speakers and room mod is the bottleneck, which represent an insurmountable law of physical constraint.
If you're using usb dac, on amd platform, as long as it's a usb native port, the latency is fine, if you're on intel, some boards will have bad usb latency through dmi pipe sharing, so you might want to get a dedicated pcie usb controller, or use optical.
If you want uncompressed 7.1, you have to go through HDMI. There are no dacs for that, you're looking at receivers. Here again, it'll be a latency problem, some receivers are just terrible.
Offline guily6669
« Reply #2 on: Thu, 03 July 2025, 20:06:34 »
Seriously, no idea...
I do have Creative Sound Blaster AE-5, they really improved a lot sound quality, but no more 7.1 on internal ones at the moment on the best ones and the software is just ruined that the sound card lost all it's power, now high power 5.1 sounds more like low power 2.1 >:D
Have to use 2 other apps just to bring the good old CMSS back which is annoying, since they lack a good upmix now.
« Reply #3 on: Sun, 20 July 2025, 21:21:30 »
I ordered one for fun, there was a great sale on the Creative site + the additional daughterboard expansion card for free. I'm a sucker for unnecessary hardware, and I need the optical-out which the Sabertooth does not have built in.
Will report back with how the Sound Blaster Audigy Fx V2 performs once I get my comp cleaned and rebuilt!
7.1 sound, DSD256 playback(highest audio res. to date), built-in 120dB DAC
« Last Edit: Sun, 20 July 2025, 21:26:39 by noisyturtle »
Offline HungerMechanic
« Reply #4 on: Mon, 21 July 2025, 16:44:24 »
Interestingly, the most discussion I see concerning sound cards concerns building retro PCs.
If somebody is rehabilitating an old Pentium or Core 2 Duo, they can build it as a Dos up to Windows XP or so PC. If you are DOS gaming, in particular, on real hardware, you want a real sound card.
You can go the expensive route and try to find a classic card, or I think there are some repro / compatible or rebuilt cards produced in China. Although there are many processors that will support older OSes, and many ways to output video, you tend to need an actual sound card for best results.
« Reply #5 on: Fri, 01 August 2025, 04:47:21 »
With the Audigy Fx V2 I can hear a sound quality difference right away, even with 2.1
It comes with software that is not intrusive, but the settings are limited.
Sound Modes that give you different presets for the Equalizer. Direct Mode which disables all software presets, nice to have a button for. Scout Mode specifically for dialogue audio for live chat, didn't bother testing.
Initially I did experience some noise feedback from my GPU, even being shielded it was super noticeable with headphones. Seating it further away seems to solved it.
All combos I tried all worked flawlessly, plug and play - Headphones/2.1/3.1/5.1/Optical
I was surprised how easy optical sound was to get working through an external DAC. Picked up the sound right away with the extra DB Pro daughter board, and I've always had tons of issues getting optical working on my ancient sea vessel of a rig. Aye she be puttin' on thee ages, but she's clean as a nun's fanny, and sounds twice as lovely!
I'mma test out 7.1 next week
« Reply #6 on: Thu, 07 August 2025, 18:23:16 »
The sound balancing between applications, and switching from speakers to headphones, is not great. I keep blowing out my eardrums forgetting 40 on my speakers sounds like 80 in my headphones.
The Creative app does have a Direct Mode that plays directly from the source, but then you lose your custom acoustic and equalizer settings.
I wish there was an auto-detect, or a simpler way to switch to headphone mode instead of opening the app and doing it every time.
The 24-bit 192,000Hz audio in 5.1(and even 2.1 & 3.1) does sound significantly better with uncompressed audio. Even to my damaged and aged ears, I can hear instruments and background noises I never noticed before.
Offline Aljami25
« Reply #7 on: Mon, 29 September 2025, 15:05:53 »
Onboard audio is plenty good now, sound cards are more for niche setups or people who really want that extra quality. Creative sticks around thanks to their name and audiophile crowd.
« Reply #8 on: Mon, 29 September 2025, 20:43:22 »
The main reason I got the Audigy Fx V2 was for 5.1 optical input.
The tweakable settings are nice to have, but I wish the software automatically detected when switching between speakers and headphone mode so you didn't have to open the panel and change over manually.
I experience zero audio overlay or drops in games when using high-output settings in 24-bit 192000hz. I do notice some drops in dialogue and background overlay noise when using my motherboard audio, or when I switch to med/low output.
So it IS better. Is it worth it for normal people? Probably not.
