Author Topic: What is your optimal monitor size?  (Read 53073 times)
« on: Sun, 06 July 2025, 19:02:25 »
I've currently got a 27" for my main screen and lately I feel like it is slightly too small.
I'm not sure if 32" would even be that much of a size difference, but at the same time I am worried about desk footprint and anything in the 40" range seens like it might be too big at an arms length away from your face.
What is your optimal size and distance/setup?
Re: What is your optimal monitor size?
« Reply #1 on: Mon, 07 July 2025, 00:26:31 »
77 inch at 1.5 meter is the ideal size for a small 10x10 rooms.
27 and 32 are non starters.
98inch also work, but your back is against the wall. 77 gives people space to move up and down with standing desk..
Online Findecanor
« Reply #2 on: Mon, 07 July 2025, 03:52:58 »
My rule of thumb has been to have enough height. Then as much width as you have space for.
According to most ergonomic manuals the top edge should not be higher than eye height, however.
And the sweet spot for PPI has been 100-110. That would make the ideal vertical span 1440 pixels.
So, the screen setup should be one or several of:
22" 4:3  1920×1440
24" 16:10 1920×1200
27" 16:9 2560×1440
34" 21:9 3440×1440
However, with ageing eyes, I think I'd like to try placing the screen further away, and then perhaps using even larger screens.
I feel that my 2' deep desk (one that I've had since childhood) is not deep enough any more.
« Last Edit: Mon, 07 July 2025, 03:54:32 by Findecanor »
« Reply #3 on: Mon, 07 July 2025, 07:33:24 »
The idea of desk depth, PPI, is obsolete 1990s computer thinking.
None of that makes any sense because the original premise of computer work is a failure ergonomically.
Humans are not anatomically suited to sit at a desk for so-long.  Their eyes are also not designed to stare at close objects shorter than 1 meter away.
Standing desk is a must, ontop of viewing distance 1.5 meters+.  It wasn't possible in the 1990s, but now we know better.
77 inch is the absolute minimum size, BECAUSE, 1-1.5 meter viewing distance is the minimum for minimized eye strain, both focal and vergeance.
« Reply #4 on: Mon, 07 July 2025, 08:32:54 »
I have used 2 screens for 20 years, ever since I bought a small one from my next-door neighbor for $10 at a yard sale.
With the internet being a constant in life nowadays, I have fallen into the habit of keeping the web up on a smaller screen on the right and doing the rest on a larger screen to the left.
Currently, I have a 27" and a 24" which are almost too big - forcing me to twist my neck when alternating between them.
But don't get me started on why square-ish screens are so much better than long screens stretched from side to side ....
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
« Reply #5 on: Mon, 07 July 2025, 12:05:18 »
That's fine for maybe 2-3 hours a day.
It's when you approach Hard Mode, 12+ PC hours,  it's really not suitable.
Offline Leslieann
« Reply #6 on: Wed, 09 July 2025, 22:18:05 »
I use dual screens and around 25-26 is best for me but I may go ultrawide on my next screen.
Anything bigger makes them too tall and too much head up down movement.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #7 on: Wed, 09 July 2025, 23:06:11 »
Sitting is wrong.
It's been killing computer people for decades.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #8 on: Thu, 18 September 2025, 20:03:05 »
I used dual 24" screens for long time. After getting problems with my neck from looking left/right 1000x a day, I switched to one 30".
No more neck problems, but having less screen-space turned out to be a problem. Too much manual window/task switching.
So, I got a 43" 4K monitor. Much better! It's like having 4x 21" 1080p monitors. Using that for a couple years now...
A Ghost From The Past
Offline hazei
« Reply #9 on: Fri, 19 September 2025, 03:40:53 »
I like the 28" BenQ RD280U (for programming) - always been a fan of squarer aspect ratios and that one is 3:2 with a resolution of 3840x2560. Gamers might not like it for being 60Hz though.
Offline TheGreatPotato
« Reply #10 on: Tue, 23 September 2025, 14:20:02 »
Yep, same here. Dual screens killed my neck, 43" 4K gives multi-monitor space without twisting your head, just scale your UI so stuff isn’t tiny.
Offline phinix
« Reply #11 on: Fri, 26 September 2025, 19:08:19 »
42"
I had 40" for years and felt right, then tried 48" at it was too big for such short distance (70cm from a screen).
Now I have 42" and its perfect.
« Reply #12 on: Fri, 26 September 2025, 22:02:58 »
42"
Samsung has a new 27"  500hz qdoled.  Exciting but 2 small.
« Reply #13 on: Fri, 26 September 2025, 22:20:34 »
42" seems huge, feels like anything bigger than around 34" you'd be constantly moving your neck slightly to adjust your line of sight
I guess it depends on depth of desk
Curved seems perfect for an upper 2nd monitor since the curvature works with the overhead angle, it would be like a spaceship HUD
also I can never go back to regular refresh rate. got to be 240 or more, or it causes tickling in the front of my brain.
« Last Edit: Fri, 26 September 2025, 22:22:56 by noisyturtle »
  • ~ BOOO ~
« Reply #14 on: Sat, 27 September 2025, 08:01:52 »
...feels like anything bigger than around 34" you'd be constantly moving your neck slightly to adjust your line of sight
I think it also depends on your visual field (the span you can change your view just by moving your eyes)
At around 70cm distance, I can see everything on my 43" just moving the eyes.
The 2x24"setup (~7inch wider) would require me to move my neck...
So it also depends on biometrics of the head etc.
« Last Edit: Sat, 27 September 2025, 08:04:38 by TheSoulhunter »
« Reply #15 on: Thu, 23 October 2025, 19:42:30 »
Is there a spray or film you can put on your monitor to prevent dust and particle attraction?
I am so sick of wiping my screen off every 10 minutes, it is insane.
Offline phinix
« Reply #16 on: Fri, 24 October 2025, 02:28:45 »
Why do you need to wipe your screen so often? Why is it so dusty? Noisy, where do you sit? :)
« Reply #17 on: Fri, 24 October 2025, 03:08:13 »
I have no idea why my room is so dusty, I've got a giant air filter and everything.
A long haired cat and keeping my window open doesn't help, but still, it is certinally one of the most dust-prone places I've ever lived.
« Reply #18 on: Fri, 24 October 2025, 07:32:38 »
Clearly, the dust is coming in from outside. Fresh air is nice, but you can easily test by closing the window for an extended period ....
« Reply #19 on: Fri, 24 October 2025, 16:43:29 »
It's got to be the nature then. Every other place I've lived has been in fairly urban areas, and I've always kept my windows cracked my whole life. This is the first place that is basically in a forest. Guess forest dirt creates massive amounts of dust, rain 24/7 or not.
Offline phinix
« Reply #20 on: Fri, 24 October 2025, 17:39:11 »
Maybe pollen?
  • ~ BOOO ~
« Reply #21 on: Sun, 26 October 2025, 22:03:52 »
Inspect the dust under a microscope (or a magnifying-glass + a high resolution camera).
Usually house-hold dust is mainly composed of dead skin and broken-off fabric-fibers.
Hard-floor instead of carpets, and not having dry skin, helps to reduce dust a lot.
For people living in very hot/dry areas, the source can be dirt/sand from outside.
As your house is surrounded by trees/meadows, pollen probably are to blame.
Offline Happyduck
  • Long-time lurker, finally decided to make an acc
« Reply #22 on: Sun, 31 May 2026, 11:28:03 »
I got the 2nd gen odyssey ark few months ago and while the screen size is awesome, it's been breaking my neck. Learned my lesson that bigger is not always better ;D
« Reply #23 on: Sun, 31 May 2026, 12:46:53 »
Lies, bigger is always better, everything else is the problem, including your neck.
  • ~ BOOO ~
« Reply #24 on: Wed, 03 June 2026, 14:22:26 »
So, the solution is to get a BIGGER NECK? :D
317369-0
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« Reply #25 on: Fri, 17 July 2026, 20:11:33 »
32" at 4K is the absolute sweet spot—it gives you that noticeable size upgrade over 27" without feeling like you're sitting in the front row of a movie theater.
« Reply #26 on: Sat, 18 July 2026, 09:58:16 »
32 is the BARE MINIMUM,  it is far from ideal. The natural vergence, relaxed position of the eye , where the eyes turn inward to focus on a forward object is approximately 1.5 meters.
You can't see 32" at 1.5 meters, it's about as big as 2 poker card.
Ideally you want at least 75-98 inches @ 1.5-2 meters.
Tpoor4 found 77 to be a good middle ground for 10 foot rooms as offices.
+Standing desk that can go down to 25-26", MUST be dual motor. at least 5 feet wide.
+200Lb motorized monitor lift that has 1 meter throw.
Offline Timc
« Reply #27 on: Fri, 24 July 2026, 11:45:44 »
agree
Offline SophieBennett123
« Reply #28 on: Wed, 09 September 2026, 09:09:19 »
For me, around 27 inches is the sweet spot. Big enough to be comfortable without taking over the whole desk.
Offline _rubik
« Reply #29 on: Thu, 10 September 2026, 01:51:25 »
Well, I used to say 2x 24" was perfect for me, but my desktop monitors have only gotten bigger and my laptops have only gotten smaller. I recently upgraded to a Dell U4025QW and I don't think I can go back.
So, I guess the direct answer is 40" uw for monitor, an 14" for laptop.
« Reply #30 on: Thu, 10 September 2026, 08:17:03 »
Ultrawide does not make sense, you have to force applications to work around it.  It's fun for about a week, then it just turns into the Linux struggle.
Games are not made for ultrawide either, so while many will play fine, the way things are laid out look off, framing is always awkward.
Offline _rubik
« Reply #31 on: Thu, 10 September 2026, 10:54:32 »
I haven't found too many issues, but then again my primary workflow is made up of a lot of horizontal slices. What use to be a series of horizontal workspaces across multiple monitors has now just fit into a single workspace/monitor. It all just sorta collapsed inwards
Offline hazil
« Reply #32 on: Sat, 03 October 2026, 06:12:00 »
I think 32" is a nice sweet spot if you already feel 27" is getting a little small. It gives you noticeably more screen space without completely taking over the desk like a 40"+ display can. Viewing distance probably matters just as much as the actual size though.
