Author Topic: Blackfriday 2025.  (Read 7543 times)
Blackfriday 2025.
« on: Fri, 14 November 2025, 10:12:29 »
OK, so
RAM,
mission-impossible, overpriced
PC Build, no bueno.
Potential plan, if you buy the CL36 samsung sticks, they're not as-crazy overpriced, and can overclock to slightly faster than stock hynix CL30 ram.
CPU,
DO NOT spend extra on X3D, NEXT GEN is coming.  Get a 9700x or 7700/x or 8700F to hold the line.
Motherboard,
GET B650,   B850 is a lie.
-- Avoid Asrock, the CPU KILLER.
GPU,
9070xt or 5070ti, those are the ONLY OPTIONS,
-- DO NOT BUY ANY OTHER GPU
-- GPUs slower than those have bad price to performance ratio.
-- GPUs faster than those are a waste of money, AMD next gen is going to be bananas.
Audio DAC,
(usb soundcard)  SMSL SU1 on sale right now for $70, buy it.
Amplifier,
FOSI audio, don't think about it, there's nothing to think about. Anything better is a waste of money, your in-room distortion is 4-orders of magnitude larger than the output of ANY well designed Class-D amplifier.
TVs
TCL still the king,  Hisense a bit weaker this year.
OLED, samsung all the way,   The S95F is actually worth it over the 90F.
Monitors,
HONESTLY,  nothing new has happened in monitors OF LATE.
ALWAYS BUY CURVED,  Don't buy flat monitors.
OLED, any oled is good, they all perform about the same, Samsung QD has significantly more vibrant colors.
-- 500hz vs 360hz,  not a huge difference, most games won't push that kind of framerate at 4K,  But it's good headroom for future GPUs.
-- Look out for PRO versions of the same monitors which come with DP2.0 ports instead of DP1.4, 2.0 gives you full 80Gigabit.
VA-monitors, KTC - H32S25E,  2560x1440, 240hz, 300nits, edgelit.  $260 regular sale price, should hit $240ish on blackfriday.
-- 4K VA monitors, not very many of these, samsung ones are way overpriced, you might as well buy oled.
-- Black smearing is still an issue, but it's much more slight on the newer panels compared to the Old ones.
-- MPRT (backlight strobe) gives you pretty decent motion clarity, but at the cost of brightness.
---- For example the KTC can only do 83nits with strobe turned on for 240hz, it can do 150nits @ 120hz. (duty cycle)
---- Oled will not have this issue, but Oled has persistence blur, so at anything less than 360hz@360fps, you actually get higher motion clarity on a strobed-LCD, VA or IPS.
---- Oled will surpass LCD motion clarity but ONLY if you can actually output 360fps+ @ 360hz and above. At 240hz even, Oled is not as motion-clear as you'd think it would be.  LCD can beat it.
IPS,  Tp4 is against IPS for general use, Contrast ratio is too poor, The image looks washed out no matter how good the IPS.
-- Movies lack depth watched on IPS panels.
-- There are miniled backlight versions of IPS monitors, NOT WORTH IT, the price -> Go OLED.
Laptops:
If you must buy one this year.
Look out for  AMD HX processor + 5070ti and above
If you get 5060 and 5070 (non ti), Vram is sorely lacking, no future durability.
Intel Lunar Lake, as you know, Tp4 has been main-ing intel's 258v lunarlake chip for a while, it's very fast for what it is, GPU is good, but support is not so great, lots of basic software bugs that are not solved.  Given that Intel is moving to Nvidia partnership, Tp4 can not in good conscience recommend ANY intel chip with their iGPU.
OLED laptops are affordable, don't spend money on LCD laptops unless you're at the $300-400 lvl.  If you're at $500 plus, it should have Oled.
Intel H series processor, It's alright if you get a good deal.
-- Don't buy the iGPU only laptops with intel-H
AMD HX, iGPU only laptops, get HX370 and above, the lower ones are too slow.
Re: Blackfriday 2025.
« Reply #1 on: Fri, 14 November 2025, 10:29:14 »
Storage prices are high. I last bought a SATA-SSD two years ago, and the prices for the same models I looked at then are at least 33% higher now. Then I read in the press this week that prices could go even higher because of demand for AI data centres (...).
I need a drive for a Linux install on my mom's computer (she has Windows 10 that can't be upgraded).
I'm going to wait for the prices on Black Friday and maybe snatch one then. Otherwise I'd have to re-purpose an old one, but you shouldn't really do that with SSDs.
The other thing is a flat 27" 2560×1440 IPS monitor for me. Unless I can find a cheap ultrawide with 1800R or flat, with the same height but more width. I don't game so I don't need high frame rate, and the integrated GPU can't provide that at high resolutions either. I'd like good sharpness, viewing angles and colour reproduction.
It is also going to be mounted on a wall behind my desk, so that I could get some distance now that I'm a bit older. There are some monitors out there that are quite thick or have the connectors facing out instead of down: those would be directly disqualified.
« Last Edit: Fri, 14 November 2025, 10:32:02 by Findecanor »
« Reply #2 on: Fri, 14 November 2025, 11:00:20 »
120hz is a quality of life experience, you don't necessarily need to game to enjoy using 120hz.
As for wall mounting, I'd recommend a gas or spring arm, there's no reason to put holes in a wall just for a small monitor, and you get more versatility with an arm, they're cheap now, not the $200 arms in Belkin's hayday.
Ultra wides are SMALL, Universally, SMALL, You'll miss the vertical space.
Depending on how old the iGPU is, it may or may not support higher refresh @ 4K.
27" is a no go for 4K, huge mistake.
4K 32 inch are Very affordable.
Dell S3225QS, flat 120hz, 4k, wide gamut, $280
But Tp4 would recommend something like, CRUA 32, 4K, $360, CURVED, 160hz, wide gamut. <if you buy from amazon, and get dead pixels, you can always exchange>   The other thing is, with these monitors, they typically have better driver chips.
^^ this should go to $300 by blackfriday.
« Reply #3 on: Fri, 14 November 2025, 12:55:02 »
Hrmpf.... Shops over here apparently already started Black Friday today two weeks early. There's a Dell 27" 1440p 180 Hz IPS for less than half of what that Dell 2160p monitor goes for locally.
SSD prices are still higher than two years ago though...
« Reply #4 on: Fri, 14 November 2025, 16:36:11 »
I got some Pit Viper Synthesizers to wear while riding my scooter
« Reply #5 on: Sat, 15 November 2025, 02:55:41 »
sn850x seems to be the only game in town if you want reputable SSD chipset.
Support is the issue. If something goes wrong, you know sandisk/wsterndigital/ samsung willl probably fix it eventually.
With the other brands, they're not nearly as responsive.
The newer chipsets are faster but kind of a waste of money.  I would say with SSDs, you always want the last gen at this point.
« Reply #6 on: Sat, 15 November 2025, 16:06:10 »
These huuuge usbC batteries,  who's this for? Who uses their phones like that, why even go outside?
« Reply #7 on: Sun, 16 November 2025, 02:26:08 »
Not sure what you mean by "uses their phones like that"...
I googled... and found images of AA and C-cell batteries with USB-C port.  Yikes... Looks like an idea invented by AI.
I suppose these LiIon batteries could have higher capacity than old-fashioned Nimh/Nicad batteries that I used to use, and it would save space when travelling by only needing a single charger -- for batteries and USB devices. But what devices even take batteries these days, and uses them up so fast that cheap Alkaline batteries isn't an option?
Powerbanks, on the other hand tend to be used by travellers and photographers so they don't run out in-between being able to use a wall-charger.
« Reply #8 on: Sun, 16 November 2025, 12:37:13 »
Ok, it seems like,  people are Unclear still, WHEN to buy 2560x1440 vs 4K.
When you increase pixel density, you reduce light efficiency. So on average, a 4K panel uses more power for the same amount of light output.
1440p also has the advantage such that you can skip scaling on AAA titles (gpu bound). PROPER image scaling is actually quite gpu intensive. That's why in most cases, they're giving you the Cheap-Version of it on GPUs, and on anything but the highest end Sony-TVs, you get the REALLLY-Cheap version.
The issue is, they can't give you great scaling without increasing latency by alot or eating into framerate.  So, Native resolution is almost Always better, image quality side of things.
It's not the end of the world, but yea, some panels and older GPUs have attrocious image scaling capability, like Tp4's older 1060, native gpu scaling is horribad. It is crazy blurry, and if you turn up sharpen, it looks like discontinuous trash.
Offline Sniping
« Reply #9 on: Sun, 16 November 2025, 23:55:25 »
like the power banks? I use 3 normally. one is a magsafe one, so you can slap it on the phone and keep the phone alive. it charges slow and makes the phone hot but convenient to use. other one is a lightweight 10k one. easy to carry, faster charge than wireless, but still not that fast and have to deal with cable. final one is a 100w 20k battery. it's to charge a laptop primarily, without an outlet. works for gaming devices too, and charges phones very fast. i carry the smallest one i can get away with, but they all have their own use cases.
« Reply #10 on: Mon, 17 November 2025, 09:29:46 »
PC gamers are stooopid.
On PC, they be like, OMG, 1440p, it dips below 60, freaking unoptimized junk, corporate greed, shiii developers.
Then on Steam deck they're like, OMG 720p 40fps, so smooooth, great experience.
Whaaaa?
« Reply #11 on: Wed, 19 November 2025, 08:31:11 »
Honestly, some really good deals on laptops going around.
The problem is they're just in TP4's mind, not there yet, in terms of performance. We're very close to that threshold when RDNA5 comes around.
« Reply #12 on: Wed, 19 November 2025, 15:25:26 »
OMFG,  Tp4 freakn' knew it.
Those round Zalman cpu coolers are now collectibles. God damn it.  Why didn't Tp4 stock up.  He saw this coming.
« Reply #13 on: Thu, 20 November 2025, 01:30:47 »
I got a 2TB external hd. $80 seemed like such a great deal.
https://www.amazon.com/dp/B07CRG94G3?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I plan of copying my movie hard drive over to this and gifting it to my parents, since they are watching a lot of movies these days. It'll be like a random film selector for them that should keep 'em busy for a few years  :))
aaaand it's $65 now
I filed for a return to get one at a lower price and Amazon offered me the difference, saving me a trip to their return center. I really wanna hate Bezos, but he makes life so easy!
« Last Edit: Thu, 20 November 2025, 21:21:17 by noisyturtle »
« Reply #14 on: Thu, 20 November 2025, 12:41:24 »
I got that Dell 27" monitor, but instead of mounting it on the wall behind the desk, on an arm or getting a new desk, I've instead planned to build a monitor shelf that partially overlaps the desk. It is going to be supported by two long legs of its own in the back and by short legs on top of the old desk in the front.
I've been considering building a slightly smaller monitor shelf for a long time but just not got around to it. I think it could be a good way for getting more space on a desk, and it would allow me to store the keyboard under the screen if I'd want to use the space for writing.
« Last Edit: Thu, 20 November 2025, 12:51:52 by Findecanor »
« Reply #15 on: Fri, 21 November 2025, 08:33:42 »
Standing desk, FTW, no to shelf.   :eek:
Offline Sniping
« Reply #16 on: Fri, 28 November 2025, 12:04:15 »
anyone go to lowes today for the first 50 promo? I was up late last night and decided against it. black friday deals pretty lukewarm this year. only thing i got was 200 treadwear tires lol
Offline Leslieann
« Reply #17 on: Mon, 01 December 2025, 06:36:26 »
What I found was ignore the hyped garbage.
I had pretty good luck this year, but I pretty much ignored the ads and just bought what I needed and got lucky. I got quite a few things at 25% off compared to actual normal prices and not inflated prices.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #18 on: Mon, 01 December 2025, 07:58:47 »
My computer died last week and I knew that it was time to upgrade mobo and CPU.
It astonished and horrified me was how expensive DDR5 memory is !!!
“So I decided to go to Iraq. I flew to Iraq. I was extremely brave. In fact, so brave I wanted to give myself the Congressional Medal of Honor. I said to my people, am I allowed to give myself the Congressional Medal of Honor?”
- Donald Trump 2026-02-19 Rome, Georgia
« Reply #19 on: Wed, 03 December 2025, 09:41:47 »
I have built my monitor shelf, and put the screen at a larger distance.
But now the screen wobbles when I type... *fsck.
« Last Edit: Wed, 03 December 2025, 09:44:17 by Findecanor »
« Reply #20 on: Wed, 03 December 2025, 23:34:20 »
got a few good deals on supplements
a pair of Pit Vipers
and a portable SSD for my parents I filled w/ 2GB of pirated movies  :thumb:
Offline Sniping
« Reply #21 on: Fri, 05 December 2025, 13:31:05 »
best deal this year by far was the 20% off paypal buy now pay later promo. I didn't take advantage since I didn't have any shopping in mind, but looking back on it I definitely could have taken advantage of this. there was another interesting one I saw where you buy uber gift cards at costco, then spend it on electronics at best buy via uber.
