Author Topic: Dust proof MX compatible switches  (Read 22067 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Mon, 11 May 2026, 10:45:46 »
Is anyone aware of any MX compatible switches that are legit dust proof?  I am probably going to be getting issued a tablet at work for a new-ish safety program.  The issue is I hate typing on a tablet sized touch screen.  So, I am wanting to swap the Cherry switches on my JD40 and my GH36 to dust proof.  The reason I need dust proof is because I work in one of the largest cast iron foundries in the US.
Re: Dust proof MX compatible switches
« Reply #1 on: Mon, 11 May 2026, 13:05:56 »
The Kailh Box switches are the first to come to mind. The slider pushes onto a lever on the side of a box, and the mechanism is inside that box, separate from the compartment with the slider. That is supposed to make them more resistant to dust.
However, I dunno if anyone in the community has actually put that to the test.
The Kailh Box also has a shroud around the stem supposed to also make it harder for dust to get inside the first compartment.
Switches from other manufacturers with just a stem-shroud have also been marketed as "dust-proof" without being significantly different on the inside than a standard MX-type switch.
BTW. There are also some vintage boards with Cherry MX (or clone) that has like a fitted rubber or plastic sheet to protect against dust and liquids (colloquially called a "keyboard condom"). Those sheets would only fit on regular stems: not shrouded ones.
I've had one with a silicone sheet but it impaired key feel considerably, but I've seen police car keyboards with a thinner sheet.
I wonder what the best way would be to make one yourself. Perhaps 3D-print a mould, lay a sheet of plastic bag material and gently use a heat-gun? SIlicone would require a two-part mould, I'd think. Silicone could be thickened to be brushable, but the result would be stiffer and uneven.
« Last Edit: Mon, 11 May 2026, 13:43:05 by Findecanor »
Offline Tactile
« Reply #2 on: Mon, 11 May 2026, 14:56:31 »
You would also need to protect the PCB. Look up "conformal coating" to find info on DIY-able protective coatings.
REΛLFORCE
« Reply #3 on: Mon, 11 May 2026, 15:11:33 »
I wonder if not a custom-cut piece of plate foam would be enough protection for the PCB. At least against dust coming in from the top.
BTW, do not use silicone sealant. It emits acid when it cures. There are people who have tried using it for sound-proofing keyboards and had their PCB destroyed.
« Reply #4 on: Fri, 22 May 2026, 16:22:58 »
You just need to buy the silicone keyboard cover.
