Author Topic: This weird AI h8 wave  (Read 3722 times)
« on: Fri, 29 May 2026, 22:50:22 »
Guys,  it's like you h8 GPUs.
Look, don't h8 GPUs,  it's the bad hughmahnns using AI improperly that is the problem.
Hughmahnns are fleshy and easily rectified,  if it gets bad,  well,  the solution is obvious.
Shovel crew hates the new Tractor,  it makes no sense, the problem is the Land Owners.
:cool:
Re: This weird AI h8 wave
« Reply #1 on: Sat, 30 May 2026, 07:54:49 »
I hate NVidia. They profited off the cryptocurrency mining boom and then the AI boom, and are part of the circular financing that will blow up and deeply cut the world's economy when the bubble bursts.
Their money is blood money.
I don't blame a GPU. A GPU is just a piece of hardware. A GPU is innocent. But I won't buy one, because that would feed the machine with money.
« Reply #2 on: Sat, 30 May 2026, 08:06:57 »
A healthy dollop of hate should go to "AI pricing"
It is nothing but an invisible roundelay to use machines to spiral prices upward while human operators can pretend to be innocent.
- D Trump 2026-10-24
« Reply #3 on: Wed, 03 June 2026, 06:39:42 »
For those who don't think that AI is a bubble: isaiprofitable.com.
« Reply #4 on: Wed, 03 June 2026, 06:48:12 »
If you want to count it that way, it's just socialized losses.
But the way capitalism works is exactly that at the end, as it fails to incorporate/ model for critical elements of the real world. .
If we didn't buy AI,  we'd have bought something else equally stupid and useless.
