Author Topic: Alixprezz vs Teemoo  (Read 2346 times)
Alixprezz vs Teemoo
« on: Sun, 12 July 2026, 11:29:37 »
Thoughts?
Which one ya'll usn' more?
Tp4 just bought 40pack of dish scrub sponge just now for $6.
317728-0
Offline Cyortonic
  • Just a railroading opossum
Re: Alixprezz vs Teemoo
« Reply #1 on: Sun, 12 July 2026, 18:11:40 »
I use Aliexpress. I never once touched Temu. For whatever reason, it just rubs me the wrong way
« Reply #2 on: Sun, 12 July 2026, 19:04:58 »
Since tarrifs it isn't worth using either anymore. Shipping is generally 4-5x the cost of the actual item.
I used to use Ali though for bootleg figurines and cosplay stuff
Offline Sniping
« Reply #3 on: Sun, 12 July 2026, 21:56:39 »
more aliexpress than temu. once i realized most of the amazon generics are the same as aliexpress stuff I started buying there when I need more than a few things and it's definitely cheaper. the dollar store is pretty clutch with the 3 item free shipping.
« Reply #4 on: Sun, 12 July 2026, 23:24:25 »
Gonna try the tide podz next, hope they're gud'.  But how bad can they be, it's a solved technology no?
