Author Topic: What mice do you use?  (Read 611848 times)
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
Re: What mice do you use?
« Reply #1000 on: Tue, 22 May 2018, 05:26:47 »
the Ultralite is so sexy..  But tp4 saving up for dat G305 atm..
Word to your mom.
I am eyeing the CST LTrac. Mean mugging it really.
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline Hodgeman
« Reply #1001 on: Mon, 04 June 2018, 16:52:40 »
G502 forever! but I’m real interested in a trac ball for work
Offline glack23
« Reply #1002 on: Mon, 04 June 2018, 17:53:03 »
Using g302 now but I think I need an upgrade soon
Sent from my Pixel using Tapatalk
« Reply #1003 on: Mon, 04 June 2018, 21:43:48 »
G302 is mercury sensor..  That's more than enough for anything 2560x1600 and under..
For 4k, is where one could actually make a case for Pixart and Hero sensor
Offline NewbieOneKenobi
« Reply #1004 on: Wed, 06 June 2018, 15:04:52 »
Sensei 300 and regretting it. The sensor isn't bad, but the shape is meh, and the build quality feels way inferior to most gaming mice from inferior companies, price at 10–20% of its price. And it already has occasional hiccups from time to time, forcing me to reconnect it from time to time. It'll take a while before I find one that's truly mine. And when I do, it may well end up being a lower model or an inferior brand compared to the great names of the gaming industry.
Offline crystalflame
« Reply #1005 on: Thu, 07 June 2018, 01:12:54 »
I'm currently using a Logitech G502! It's not bad, and Amazon accidentally sent me two of them so that was nice  :D
Offline slk
« Reply #1006 on: Thu, 07 June 2018, 01:14:50 »
Logitech G403 but I do swap with a Razer Naga every once in a while.
Offline Phitness
« Reply #1007 on: Thu, 07 June 2018, 02:29:16 »
Been using a Razer Naga since the first one came out and a Razer Deathadder.  Hate the software but love the shape.
Offline johngodsmith
« Reply #1008 on: Thu, 07 June 2018, 04:09:02 »
Ninox Venator
Cheap, 3360, nice shape
Offline RobotRogue
  • No.
« Reply #1009 on: Thu, 07 June 2018, 10:42:07 »
Work: Logitech MX Master.
Home: Corsair M65
Offline dankdesire
« Reply #1010 on: Thu, 07 June 2018, 11:06:35 »
Rival 100, fits my hand perfectly
Offline Pewpew
« Reply #1011 on: Thu, 07 June 2018, 20:30:59 »
Logitech G900
Offline MrDongblaster
  • Dr. Pepper Zero Sugar Enthusiast
« Reply #1012 on: Mon, 11 June 2018, 14:16:16 »
Logitech G900
The G900 has changed my view on wireless mice. I came from a deathadder and was worried about going wireless for gaming. I got the G900 on crazy sale and it's been nothing short of perfect. It holds a charge for like 5 days of heavy use. Love it.
Offline MonsterZero
« Reply #1013 on: Tue, 12 June 2018, 04:02:37 »
EC2-A
best ever
٩(͡๏̯͡๏)۶
Offline fracno
« Reply #1014 on: Sat, 16 June 2018, 20:05:39 »
I use a Logitech G900 and I absolutely love it. I was a little worried about going wireless but I've never had an issue before.
Offline rich1051414
« Reply #1015 on: Sat, 16 June 2018, 23:34:04 »
Loved mine, but be careful with pressing too hard to click. Use a light finger. That mouse has a hinged left and right click, which is great since there is no plastic fatigue, but it is bad because you can more easily exceed the specifications of the switch(in spite of them using the best microswitches). The switches are easy to replace though, as they have their own daughter boards, but opening the mouse is a royal pain.
Offline fracno
« Reply #1016 on: Sun, 17 June 2018, 04:39:45 »
Hmm that’s good to know! Thanks for the info. I don’t think I have a particular heavy click but things get a little aggro while gaming. And raging. Haha
« Reply #1017 on: Sun, 17 June 2018, 08:15:19 »
Logitech mice have an H-Bar stem which prevents overtravel on the switches.
The new ones have stem contact surfaces which are slightly tilted, and similarly prevents overtravel.
You can press as hard as you like, it will not cause overtravel.
That doesn't mean you can't hurt it if you tried to,  but no NORMAL HARD clicking will damage the switch in any greater capacity than light ones.
