Author Topic: [CLOSED]EPDM 40a O-ring group buy. [FINI]  (Read 53850 times)
Offline captain
« Reply #50 on: Thu, 23 February 2012, 15:59:55 »
I'll be in for 3 sets if I can figure out how to PM and copy paste on tapatalk. If you don't hear from me with the right info, please PM me with the format of what data you need.
PS OP: I mean no offense, but please review the meanings of the words "then" and "than". You appear to be transposing them. Common Internet mistake that we need to fight. :-)
« Last Edit: Thu, 23 February 2012, 16:02:18 by captain »
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline rindorbrot
« Reply #51 on: Thu, 23 February 2012, 17:15:17 »
If someone in Germany can proxy this, I'd be in for 1 set, too!
« Last Edit: Thu, 23 February 2012, 17:18:59 by rindorbrot »
Offline WhiteFireDragon
    • youtube
« Reply #52 on: Thu, 23 February 2012, 17:54:45 »
Quote from: piken;522114
Sordna, the o-rings from WASD are not actually 1.6mm they are a -009 o-ring which is 1.53mm +-.08. They can be anywhere from 1.45mm to 1.61mm. This is a normal thing for rubber o-rings.
Quote from: piken;522140
I have updated the post, but you need to look over the sizing a bit more. 008 and 009 are the same cs material size based on the ASE standard 1.53+-.08 while the ID is different. 4.73+-.13 for 009 vs 4.47+-.13 for 008.
The size of the WASD o-rings are 009 as I sent off one of my o-rings the to company in order to work out the order. They are the ones that correctly sized the o-rings based off of a sample o-ring from my previous order from WASD.
Quote from: piken;522943
The sizing they had listed in the initial quote based on the o-ring I sent them is 5mm x 1.5mm. I have begun the paperwork of finalizing the order based on the 40a o-ring from WASD I provided. The final sizing will be as follows, 4.5mm +- 0.13 x 1.5mm +- 0.08.
This is based on the measurements they took from a sample o-ring I provided. This might not be the official size reported of the WASD o-rings, but they are identical to what I have from them currently and enjoy.
I just wanted to jump in here and comment about your sizes a bit more. The -009 size you mentioned is wrong, it has a ID of 7/32”, which converts to roughly 5.56mm, much too large for a keycap stem. Based on some charts, it has a actual diameter of 5.28mm, still too large for a keycap stem. The stem has a diameter of about 5.10mm, so the O-ring’s ID needs to be smaller than that. You said the ID of a -009 is 4.73mm, which is just a wrong measurement. Both O-rings sold on WASDkeyboard are not -009, they are -008. As far as the thickness, -009 and -008 are the same though, but the ID makes a huge difference in the fit of these.
Second, I think you’re trying to force the two different measuring systems too much. US standards in inches and metric system are different, although you can do conversions. Sordna posted a pic of all the different O-rings I ordered, and you can see a visible difference in diameters and thickness of a 5mm x 1.50mm metric size Oring vs a -008 (3/16” x 1/16”). So you can’t already claim these O-rings will be identical to the ones on WASD without getting a sample from the company first. The -008 O-rings that I have are already tight enough with a converted size of 4.76mm ID, so if you’re ordering 4.50mm with a tolerance of +-0.13mm, then there is a chance they could even be 4.37mm ID, which might be too tight for these to fit on the stems.
If I were personally running this GB, I would just stay with the tried and true 5mm x 1mm or -008 size. The -009 you mentioned was just a wrong measurement, and 4.5mm ID might be too tight. Although since 40A is pretty soft rubber, it can stretch, but for the ease of installations, I would stick with 5mm ID size.
« Reply #53 on: Thu, 23 February 2012, 19:58:56 »
PM'd for 1 set
Offline pyro_dragun
« Reply #54 on: Thu, 23 February 2012, 20:59:03 »
PM'd for 2 sets.
Offline Dejahboi
« Reply #55 on: Fri, 24 February 2012, 03:23:59 »
PM'd for another 2 sets :)
Offline liquidsteel30
« Reply #57 on: Fri, 24 February 2012, 23:06:59 »
PM sent for one set :)
Offline m_enanos
  • tbb
« Reply #58 on: Sat, 25 February 2012, 17:28:52 »
PM sent; one set to the Netherlands!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #59 on: Sat, 25 February 2012, 18:04:03 »
would like to see whitefiredragon's concerns addresses
Offline omuerte
« Reply #60 on: Sat, 25 February 2012, 18:09:25 »
pm'd for 2 sets
Click Clack
Offline bbbbqq
« Reply #61 on: Sat, 25 February 2012, 20:37:08 »
pm sent for 2 sets, Canada.
Offline kwang2009
« Reply #62 on: Sat, 25 February 2012, 23:31:24 »
In 4 2.
Offline h2oxide
« Reply #63 on: Sun, 26 February 2012, 00:50:26 »
So just to clarify these are the same spec as the WASD 40A O-Rings?
Offline snowboarder3
« Reply #64 on: Sun, 26 February 2012, 16:07:23 »
Quote from: h2oxide;526399
read the damn thread
Offline h2oxide
« Reply #65 on: Sun, 26 February 2012, 18:18:24 »
So can the OP reply to WhiteFireDragon?
Offline Bertross
« Reply #66 on: Sun, 26 February 2012, 19:14:43 »
h2 looks like this is the spec.
They are 4.5mm+-0.13 x 1.5mm+-0.08 EPDM 40a o-rings.
http://www.wasdkeyboards.com/index.php/products/keyboard-accessories-2/cherry-mx-rubber-switch-dampeners.html
they seem to be very similar.
Quote from: snowboarder3;527130
Lol so much rage!
« Last Edit: Sun, 26 February 2012, 19:17:03 by Bertross »
REALFORCE 86UB / FILCO MJ2 87 BROWN PBT WHITE/BLUE
Offline sordna
« Reply #67 on: Sun, 26 February 2012, 20:33:32 »
The ones offered here are overall slightly smaller (both in diameter as well as in thickness) than the WASD ones.
Offline cix
« Reply #68 on: Sun, 26 February 2012, 21:49:58 »
PM'd for 5 sets.
Offline Ahlitah
« Reply #69 on: Sun, 26 February 2012, 22:05:23 »
2 sets to Canada
Offline OPTiK
« Reply #70 on: Sun, 26 February 2012, 22:43:05 »
In for 3 sets! Hopefully all the concerns will be addressed :)
Offline quake4mhg
« Reply #71 on: Mon, 27 February 2012, 06:16:36 »
PM'd for 1 set. Thanks.
Offline Inochi
« Reply #72 on: Mon, 27 February 2012, 10:23:46 »
PM'ed for 2 sets.
Offline Reds4Lyfe
« Reply #73 on: Mon, 27 February 2012, 10:39:13 »
In for 1.
Offline devouringone3
« Reply #74 on: Mon, 27 February 2012, 14:08:11 »
These are *similar of the most popular
"pack A: optimal noise dampening, small key travel reduction $9
40A, 3/16 ID, 5/16 OD, 1/16 W"
in the previous group buy hosted by WhiteFirePhoenix... but cheaper
*0.25mm less inner diameter (4.75 -> 4.5 these) and 0.1mm less thickness (1.6 -> 1.5 these)
« Last Edit: Mon, 27 February 2012, 14:22:09 by devouringone3 »
Offline sordna
« Reply #75 on: Mon, 27 February 2012, 14:11:54 »
Argh, please don't perpetuate the confusion !
The o-rings offered here are 4.5mm ID, 1.5mm W metric o-rings. The "pack A" you are referring to are approximately 4.75mm ID, 1.6mm thick.
« Reply #76 on: Mon, 27 February 2012, 14:22:34 »
Quote from: sordna;528310
Sorry, I "fixed" my *post.
"4.5±0.13mm x 1.5±0.08mm" would become 4.63 and 1.58, which is very similar, but could also diverge even more if "-" sign applies for the least.
« Last Edit: Mon, 27 February 2012, 14:24:43 by devouringone3 »
Offline sordna
« Reply #77 on: Mon, 27 February 2012, 14:50:38 »
I just measured my 008 o-rirgs with my vernier caliper and got 1.8mm thick. Perhaps the sizing charts ARE right, compared to converting by 1/16 * 2.54 which yields 1.6mm.
See this post ... the photo will also show you a visual, just compare pack X or H (1.5mm) to pack A or B (1/16").
In any case, the o-rings offered here will work better for genuine Cherry short-stem keycaps than the usual 008 o-rings for folks that want minimal key travel reduction.
Offline Bertross
« Reply #78 on: Mon, 27 February 2012, 18:37:52 »
Quote from: Bertross;522415
Put me down for 4 sets, postage to australia.
PM coming. Edited to 4 sets.
« Last Edit: Mon, 27 February 2012, 19:41:08 by Bertross »
Offline blert
« Reply #79 on: Mon, 27 February 2012, 19:50:09 »
I'm in for two sets.
Offline gladiusgg
« Reply #80 on: Mon, 27 February 2012, 23:28:51 »
interested to get 3 sets
Offline JSchool
« Reply #81 on: Tue, 28 February 2012, 03:55:13 »
I'll take 2, PM sent.
Offline kikkobots
« Reply #82 on: Tue, 28 February 2012, 17:11:26 »
are we going to get a list of confirmed buyers?
Offline f4d3
« Reply #83 on: Tue, 28 February 2012, 17:16:34 »
A list and quantity ordered would be nice. It would also be nice to see if our orders got sent to you.
Offline ryan92084
  • Consumer ****
« Reply #84 on: Tue, 28 February 2012, 18:09:45 »
I already sent in a pm but 2 sets for me
RiP *ucky Shine(ing)
Offline CaiSter21
« Reply #85 on: Tue, 28 February 2012, 19:35:04 »
OP hasn't been here since 2/23.... wonder what happened...
Ducky Shine DK 9008S Red LED |Rosewill RK-9000BR
Offline regca
« Reply #86 on: Tue, 28 February 2012, 21:18:54 »
he signed on today it's all good
pm set! 2 sets yayy
Offline nowincolor
« Reply #87 on: Tue, 28 February 2012, 22:31:30 »
In for 2 sets!
Offline gladiusgg
« Reply #88 on: Wed, 29 February 2012, 09:43:28 »
ts has yet to reply to my pm. dont know if hes still around...
Offline Inf3rn0_44
« Reply #89 on: Wed, 29 February 2012, 19:32:11 »
Quote from: gladiusgg;530743
yeah same here, im in for one set
|IMO 1.0 Frankenmouse WMO Internals |
|Access-IS AKC090 Ghetto Reds w/ O-Rings |
Offline Wildcard
  • When caffeine isn't enough
« Reply #90 on: Wed, 29 February 2012, 22:45:32 »
In for 4 sets
PM sent
Offline bobola
« Reply #91 on: Thu, 01 March 2012, 00:15:48 »
PMed for one
Offline rknize
    • metaruss
« Reply #92 on: Thu, 01 March 2012, 01:03:24 »
Previously PMed for 5 sets.
Russ
Offline piken
« Reply #93 on: Thu, 01 March 2012, 06:49:24 »
Issues at work and orders still rolling in this morning have extended the purchase close data to 03/07. Will update in the next few days.
Offline Machupo
« Reply #94 on: Thu, 01 March 2012, 11:31:30 »
in for one :)
KBC Poker Blue (Soon to be Clear)
Offline CaiSter21
« Reply #95 on: Thu, 01 March 2012, 12:20:44 »
Quote from: piken;531872
at such a cheap price, you would have to be a fool not to buy them
Offline FlipBack
« Reply #96 on: Thu, 01 March 2012, 17:35:02 »
PMed for 1 set.
Offline Bertross
« Reply #97 on: Sat, 03 March 2012, 04:15:21 »
Cancelling my 4 sets as im going to bundle my order with another Aussie in this groupbuy to save postage and hassle. Cheers. PM coming to confirm to the cancellation. The number will be the same but added to another member.
Offline Denonic
« Reply #98 on: Sat, 03 March 2012, 18:56:54 »
Order PM'd.
Offline Anyguy4321
« Reply #99 on: Sat, 03 March 2012, 21:09:42 »
Order PM'ed.  In for 2.
