Author Topic: Corsair K60 for $80  (Read 2689 times)
Offline dreamingftw
Corsair K60 for $80
« on: Thu, 01 March 2012, 23:52:57 »
Corsair Vengance K60 down to $80. Get their the matching mouse for $40 AR. Pretty good deal. I know some people still want this board despite it being hybrid.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823816001
http://www.newegg.com/Product/Product.aspx?Item=N82E16826816006
Offline bavman
Corsair K60 for $80
« Reply #1 on: Thu, 01 March 2012, 23:59:27 »
is it just those media keys in the top right hand corner that are not mechanical?
Offline jwaz
  • * based mod
  • #geekhack on freenode
Corsair K60 for $80
« Reply #2 on: Fri, 02 March 2012, 00:07:30 »
The whole top row and maybe the numpad?
Offline bavman
Corsair K60 for $80
« Reply #3 on: Fri, 02 March 2012, 00:08:44 »
Ah just found it. A review on newegg said ESC and f1-f12 are rubber dome.
Its a really crappy way for corsair to cut corners and save themselves some money
Offline dreamingftw
Corsair K60 for $80
« Reply #4 on: Fri, 02 March 2012, 00:31:11 »
I was excited about buying this board before I found out about the rubber domes.
Offline tsangan
  • 1000/600
Corsair K60 for $80
« Reply #5 on: Fri, 02 March 2012, 00:32:55 »
ooooo I want those rubber keys!
Keyboardless
Offline Lmnr
  • The Jack Of All Trades
    • W.W.C.
Corsair K60 for $80
« Reply #6 on: Fri, 02 March 2012, 09:00:11 »
I Don't get how the k90 is the same thing with macros and lighting makes it cost 30 bucks more.
Might as well make it a full red mx keyboard and stop cutting corners..
Sent from my MOTWX435KT using Tapatalk
Peripherals:
Realforce 87uw with grey caps,Ducky YOTR Blues,Realforce 104ug Hipro,Zowie Am FG,WMO 1.1a,Sidewinder X3
Offline WhiteFireDragon
    • youtube
Corsair K60 for $80
« Reply #7 on: Sun, 04 March 2012, 03:07:03 »
Quote from: Lmnr;533068
Same concept when you look at Razer's normal black widow vs the ultimate version.
Corsair K60 for $80
« Reply #8 on: Mon, 05 March 2012, 22:25:34 »
It's not cutting, corners, they really BELIEVE that this is good for the endusers.  I DON"T agree,, but they truly think that n00bs will hit keys by mistake, and it is very easy for that to happen on reds.
Offline Lmnr
    • W.W.C.
Corsair K60 for $80
« Reply #9 on: Mon, 05 March 2012, 22:31:57 »
Well even so they shouldve just gone with blacks if they wanted to fix that issue.. oh well the k90 looks better but its got the same problem as the k60.
anyone have news on them releasing new ones?
Peripherals:
Offline jwaz
  • * based mod
Corsair K60 for $80
« Reply #10 on: Mon, 05 March 2012, 23:11:43 »
bull****. they should have used blacks. fail.
