Author Topic: smaller portable board with costar stabilizer?  (Read 3501 times)
Offline FinancialWar
« on: Sun, 04 March 2012, 22:39:05 »
hello, guys
I am looking for a portable board such as the KBC poker or similar with costar stabilizer. Does such a board exist?
Offline naranja
« Reply #1 on: Sun, 04 March 2012, 22:50:38 »
Only mini keyboard with costar I can think of is the noppoo choc mini. have you looked into that?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 04 March 2012, 23:47:36 »
356 mini?
« Reply #3 on: Mon, 05 March 2012, 05:33:39 »
Quote from: naranja;535377
have you had any experience with the choc mini? Are they as good as Filco when it comes to typing experience?
Offline HaiiYaa
« Reply #4 on: Mon, 05 March 2012, 06:07:00 »
Is that really costar? The keys feel so wobbly on the 3 noppoo's I had
« Reply #5 on: Mon, 05 March 2012, 06:24:20 »
just take off the key and inspect it.
Offline theLiminator
« Reply #6 on: Mon, 05 March 2012, 06:26:03 »
Don't quote me on this, but I think the Tenkeyless CM storm quickfire is made by costar, and should have costar stabilizers.
Offline HaiiYaa
« Reply #7 on: Mon, 05 March 2012, 06:41:36 »
Quote from: FinancialWar;535602
I had 3 different noppoo choc mini's and all of them had wobbly spacebar and enter
« Reply #8 on: Mon, 05 March 2012, 07:50:57 »
Quote from: theLiminator;535603
Thanks for the suggestion but CM storm TKL is not exactly portable. I am looking for something similar in size to the KBC poker.
Offline GeorgeStorm
« Reply #9 on: Mon, 05 March 2012, 08:33:40 »
What's wrong with the poker?
It's a lovely board
Poker with blacks
My flickr
« Reply #10 on: Mon, 05 March 2012, 08:41:17 »
I don't like cherry stabiliser
Offline sordna
« Reply #11 on: Thu, 08 March 2012, 21:58:06 »
Deck 82 or Data911 TG3: It has no stabilizers on the shifts/enter/backspace, so it feels great. Only the spacebar has a (cherry) stabilizer, however for the spacebar a cherry stabilizer may be not as bad as it would be for shift/enter/backspace.
Offline BiNiaRiS
« Reply #12 on: Thu, 08 March 2012, 23:28:19 »
cherry stabilizers > costar stabilizers
KMAC 2 w/ErgoClears
Offline pitashen
« Reply #13 on: Fri, 09 March 2012, 02:22:30 »
Quote from: BiNiaRiS;539841
lol nice. I actually found that both are likable but thumbs up for Bini!
« Reply #14 on: Fri, 09 March 2012, 03:17:43 »
yeah right...
just like Asian ****s > Black ****s
Offline RiGS
« Reply #15 on: Fri, 09 March 2012, 05:05:50 »
Quote from: HaiiYaa;535610
Well, it's the common issue with the costar type stabilizers, and it is easy to fix this problem.
It's because of the holes of the stabilizers not being snug up against the stabilizing wire. The wiggle room lets the keycap bounce around. One have to apply some grease to the stabilizer inserts, or using tape on the wire to fix that.
« Reply #16 on: Fri, 09 March 2012, 09:23:44 »
Quote from: ripster;540038
Given that Geekhack is 99% Asian I'd be careful with that generalization.
WTF,,, is this true????
Offline alaricljs
  • I be WOT'ing all day...
« Reply #17 on: Fri, 09 March 2012, 09:24:17 »
Do we need to start making sarcasm signs?
Filco w/ Imsto thick PBT
Offline Typhaeon
« Reply #18 on: Fri, 09 March 2012, 10:15:30 »
There's a link for a $50 TG3 BL82 (Deck 82) in the Great Deals forum.  If you don't mind MX Black switches, the PS/2 connector, and the fact that you'll need your own mat and feet for it, I think it'll work nicely for your purposes.
