Author Topic: Got My First Mechanical KB  (Read 3193 times)
Offline herseil
« on: Mon, 05 March 2012, 10:03:09 »
Hi, yet another newbies here :smile:
I've finally bought myself first mechanical keyboard :first:, a Rosewill RK-9000BR (brown switch) I've done most of my research here at geekhack before I decided to jump in. So, many thanks for all helpful members here :smile:
A little question here, is there any way to handle the  squeaky key problem? Well it not always make the squeak but still sometimes it get kind of annoying (the backspace key)
Offline Ahlitah
« Reply #1 on: Mon, 05 March 2012, 10:39:06 »
enjoy the board!
When I jumped back into mechanical that Rosewill Brown as my first as well.
Turns out I don't like the Brown switches, but hope your enjoying them!
you will have to lube the squeaking keys with some white lithium grease or similar.
read this:
http://geekhack.org/showthread.php?22656-Gallons-of-Spooge-The-Official-Ripster-Lubricant-Experiment-Thread
I solved my issue with squeaking by adding o-rings, is also quiets down the keyboard. It may not work for you though, so grease it prob a better solution.
« Reply #2 on: Mon, 05 March 2012, 21:53:49 »
Quote from: herseil;535731
Congratulations.. I highly recommend a custom paint job... That roswill logo is just Toooo,,, girly-fonted
Offline whiskerBox
« Reply #3 on: Mon, 05 March 2012, 21:58:27 »
Welcome to geekhack. Orings may help with noise and WASD sells them
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Kamikaze K
« Reply #4 on: Mon, 05 March 2012, 22:03:21 »
Nice board!  The red mounting plate looks great!  It's very similar to the CM reds except for the Tenkeyless/fulldeck difference.  Saying that... since it's a Costar OEM, the two boards probably came from the same place!
FILCO Majestouch 2 Camouflage Tenkeyless [Black]
DUCKY DK9008 Shining [Blue]
CM STORM Quickfire Rapid [Red]
TOPRE REALFORCE 87U
« Reply #5 on: Tue, 06 March 2012, 08:07:06 »
Quote from: Kamikaze K;536458
I firmly maintain that cm quickfire is the same as filco, except for the position of status lights.
Has anyone taken it apart,, the quickfire??
Offline Kamikaze K
« Reply #6 on: Tue, 06 March 2012, 09:59:57 »
Quote from: tp4tissue;536786
Great lil'boards, the CM's.  I do think that the stock keycaps on the Filco's are better though.
TOPRE REALFORCE 87U
Offline dreamingftw
« Reply #7 on: Tue, 06 March 2012, 10:47:56 »
Wlcm2GH
Offline herseil
« Reply #8 on: Tue, 06 March 2012, 12:12:39 »
Thanks for the welcomes :smile:
I'll buy a keycap puller and some grease first then. Hopefully it will fix the squeak.
Another thing : does anyone know if the new RK-9000 have the same Filco controler PCB like the old RK-9000?
« Reply #9 on: Tue, 06 March 2012, 21:08:35 »
Quote from: herseil;536939
Careful bro, if you go down the path to buy cases,, it's like a bucket of thermite for your pockets...
« Reply #10 on: Tue, 06 March 2012, 21:08:52 »
Quote from: Kamikaze K;536840
caps are getting replaced anyway.
