Author Topic: My Filco MX Blue are wearing out fast?  (Read 7233 times)
Offline af22
« on: Thu, 08 March 2012, 12:31:08 »
Hello,
I bought a brand new filco 10 keyless keyboard with Cherry MX blues in August 2010.  I'm wondering what the life of these keyboards are, as it has been significantly worse then what i expected.
Currently, 4 of my keycaps (Letters A,S,C,N) have the paint worn off, and 4 additional keycaps are not far (Letters, E,R,T,M)
In addition, I had 4 switches start to chatter bad which i swapped out (Letters A,S,Y,O).  And now my R, D, V is starting to also chatter.
I've noticed that the new switches I put in are alot stiffer then the 1.5 year old ones (i simply swapped the switches with right modifiers (Alt, Win, RClick, and Ctrl), so they are the same batch that came with the board).
I admit that i am a heavy typer, and i bottom out my keyboard every single stroke (i like it loud).  Am i doing something wrong here to make my keyboard wear out faster then it should?
I just ordered 25 replacement switches to stock up, and also a pack of rubber dampers to help with the bottoming out.
Any advice or comments?  This keyboard is getting more expensive by the year if I need to replace switches annually.  My old logitech keyboard which i used for many years still works strong with no paint wear or switch problems.
Thanks.
Offline fstop
« Reply #1 on: Thu, 08 March 2012, 14:39:00 »
Keycap wear is normal, especially under heavy use. ABS caps that come with Filcos are decent, but compared to PBT or Doubleshots they are pretty cheap and you will see wear fast. I suggest getting a new set of PBT if wear is your main concern (doubleshots are more for looks, though still more durable then ABS). It'll run about $40-$50 for a set but will definitely last long enough that you won't have to worry any more. Plus they feel better.
As for switches dying, I think cherry switches have an estimate of 20 million actuations (50 million reported on cherry's site). Not sure what's going on in your case though! It does seem abnormal.
CM Storm Quickfire MX Reds
CM Storm Quickfire MX Blues
Filco Majestouch-2  MX Browns
RealForce 87uw uniform 45g
Offline Squelos
« Reply #2 on: Thu, 08 March 2012, 14:58:44 »
20million actuations actually is quite a lot when you think of it. Even if some switches are far more used than others, killing a switch still isnt an easy task IMHO.
Plus I dont know what a switch does when it dies, but it probably wont be like rubber domes, which stop registering every keypress.
Offline silat
« Reply #3 on: Thu, 08 March 2012, 15:35:20 »
Quote from: ripster;539401
20 Million MTBF sounds good until you run it through a stochastic model involving 104 switches.  People get all poisson'd when the see the results.
Rip do you have links to Cherry switches being run stochastically ?:)
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline Bird
« Reply #4 on: Thu, 08 March 2012, 16:11:00 »
oh wow :D
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Thu, 08 March 2012, 16:15:22 »
I know the numbers for hard drives w/ 1,000,000 hours MTBF.  They are not pretty.  It's why tech-heads refuse to use RAID5 on more than 4-5 disks.  The possibility that a 2nd drive fails while rebuilding the array from a previous failure gets shockingly close to 1:1 rather quickly.
Filco w/ Imsto thick PBT
Offline Bass
  • Formerly Forte
« Reply #6 on: Thu, 08 March 2012, 20:28:27 »
Cherry MX switches are quite prone to chattering when they get dirty, so in many cases depressing the switch in question while blowing some compressed air generally does the trick.
Offline Tony
« Reply #7 on: Thu, 08 March 2012, 20:40:34 »
It looks like you will be better off with Logitech rather than a Filco.
Mechanical keyboards are designed to lessen the bottoming out to save the finger distances and make typing faster with less force. You do just the opposite and make the keyboard worn fast.
If you can afford the replacement cost, then please go on.
« Reply #8 on: Thu, 08 March 2012, 20:41:00 »
Quote from: Forte;539704
Fvck it, buy new switch. Or swap
Offline af22
« Reply #9 on: Thu, 08 March 2012, 20:55:06 »
Quote from: Tony;539715
That's very interesting.  I do type pretty hard and I can burst over 100 wpm.
On this keyboard alone, in the last 18 months, i've spent $262 already.  I'll see how long it'll last until the next "repair"
I've tried the can air on the switches, it didn't seem to help.  I can tell my switches are physically worn when compared to the lesser used keys.
thanks for all the replies.
Offline Exort
« Reply #10 on: Thu, 08 March 2012, 21:08:44 »
Quote from: fstop;539368
Isn't most double shot ABS?
Offline rknize
    • metaruss
« Reply #11 on: Thu, 08 March 2012, 21:16:09 »
He types hard and likes the noise.  He needs a Model M or a Unicomp.  PBT keys and built like a truck.
As far as chattering, do you mean they audiably chatter or you are getting key bounce?  Hitting the keys hard should not accelerate contact wear, due to how the switches work.
Russ
Offline af22
« Reply #12 on: Thu, 08 March 2012, 22:21:55 »
Quote from: rknize;539739
When i say chatter, i'm getting repeating keys. like waassdd.
I had a model m when i grew up, and it is still one of my favorite keyboards.  I also enjoy the Dell with black alps.  I bought the filco so i can have a modern looking keyboard to match the rest of my hardware.
Offline rknize
    • metaruss
« Reply #13 on: Thu, 08 March 2012, 23:44:45 »
I asked because some of the blues I have do a weird buzzing thing sometimes.  But it doesn't affect the output of the key.
Have you tried just reflowing the solder joints on the suspect keys?
Russ
Offline Tony
« Reply #14 on: Fri, 09 March 2012, 05:17:51 »
I think you should buy a Unicomp or old IBM model M, since buckling springs are much tougher than Cherry MX switches. And they sound much louder, which you'll like.
Offline fstop
« Reply #15 on: Fri, 09 March 2012, 05:58:57 »
Quote from: Exort;539734
Yes they are. And I meant that doubleshots were more durable in that the legends won't fade nearly as fast, which is the problem OP is experiencing.
Offline zirb
« Reply #16 on: Fri, 09 March 2012, 06:44:16 »
Quote from: fstop;539968
And I meant that doubleshots were more durable in that the legends won't fade.
FTFY
Offline Surly73
« Reply #17 on: Fri, 09 March 2012, 11:29:23 »
Quote from: af22;539219
Hello,
Thanks.
Um, how to ask this....
How clean is your keyboard environment?
Dirt will accelerate wear and malfunction.
Offline af22
« Reply #18 on: Tue, 13 March 2012, 09:44:51 »
I just wanted to update everyone on this thread.
I installed some 40A red o-rings on my mx blues, and somehow it have removed all my keyboard chatter problems.
I can only theorize why this is occurring.  My chatter keys were significantly easier to depress, and maybe now the o-rings are removing some of the key stroke preventing it from double registering.
Either way, i'm loving how the keys feel now with the o-rings.
Offline Chobopants
« Reply #19 on: Tue, 13 March 2012, 10:59:35 »
Highly recommend grabbing some PBT keys in the group buy section to fix that wear problem on the caps. All my filcos have them now and there isn't a lick of wear (esp on the side printed keys :). The one minor thing is the white keys show dirt pretty easily, just need to wipe them down once in a while.
Kind of have forgotten what stock filco keys even feel like. :P
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
