Author Topic: Likelihood of this selling?  (Read 2522 times)
Offline FerretBuster
« on: Mon, 12 March 2012, 16:48:26 »
OK I'm burning to buy myself a Filco with blues, specifically this one - http://www.keyboardco.com/keyboard_details.asp?PRODUCT=648
But I am worried that this won't sell - http://geekhack.org/showthread.php?28452-Filco-Majestouch-2-Cherry-mx-browns-Full-Size-UK-Layout&p=541288#post541288
I have the capital to buy a Filco with blues now, however I don't want to get it then end up with two boards. Also if I happen to hate the blues for some reason (Which I highly doubt - how easy will a fullsize blue board be to sell?)
NOTE: These are UK layout and I will sell within the UK only.
« Last Edit: Mon, 12 March 2012, 17:15:15 by FerretBuster »
Offline eltocliousus
« Reply #1 on: Mon, 12 March 2012, 17:37:47 »
Is this just advertising in disguise? Seems like it, of-course it will sell it's a Filco, just give it time and if necessary drop the price a little after a given time.
« Reply #2 on: Mon, 12 March 2012, 17:48:12 »
I can remove the link it if you want. That is definitely not what I was trying to do.
« Reply #3 on: Mon, 12 March 2012, 17:50:02 »
Quote from: FerretBuster;543761
I can remove it if you want. That is definitely not what I was trying to do.
No not at all, it just seemed a little strange asking if a Filco will sell, I'd be hard pressed to not buy it myself had I not just recently made a large keyboard purchase.
Offline morgofborg
« Reply #4 on: Mon, 12 March 2012, 18:05:50 »
I think you are fine on both counts. Your TKL w/ browns should sell no problem, and I don't think it is all that hard to sell a full size board either. Some people really need that ten key.
« Reply #5 on: Mon, 12 March 2012, 18:09:41 »
it has been up for [STRIKE]ONE[/STRIKE] TWO days.. full size filcos don't sell as quickly as tenkeyless, but they eventually sell. like first guy said, give it time.
« Reply #6 on: Mon, 12 March 2012, 18:17:12 »
I know how long it's been up, I was just wondering - I have no Idea how fast Filco's sell from within the UK. Let alone ones that are full size. I just want to feel a bit more secure if I purchase the Filco with blues before my Filco brown sells.
Offline Reptile
« Reply #7 on: Mon, 12 March 2012, 18:31:46 »
Your good I sold full size browns a couple months ago. Took about a week
Sent from my mobile
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
« Reply #8 on: Mon, 12 March 2012, 22:05:34 »
Quote from: FerretBuster;543677
If it's the burning,, it could be gonorrhea
« Reply #9 on: Tue, 13 March 2012, 00:21:15 »
Quote from: ripster;544079
Dude, that's threadclapping.
raff out rowd
Offline notnay
« Reply #10 on: Tue, 13 March 2012, 00:31:30 »
You'll be fine, I'm sure someone out there, somewhere, is willing to buy it.
Try offering a free hat with it.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #11 on: Tue, 13 March 2012, 04:29:49 »
I could mod the browns to blues instead but that probably no the best optiob
