Author Topic: Corsair Vengeance K90 vs Corsair Vengeance K60 vs CM storm Trigger/quickfire?  (Read 3211 times)
Offline spitfire6000
Whats the best keyboard out of this bunch?
I understand that the cm storm has ALL mechanical keys while te corsair has regular rubber F1-F12 and macro keys, but whats the better keyboard overall?
The reviews look very nice for the corsairs, but even nicer for cm storm...but the cm storm doesnt have backlighting.
Which is the better choice cm storm or corsairs?
Quote from: spitfire6000;552030
If you don't do data entry, by that I mean, You make spreadsheets less than once every 2 weeks,, THEN get the CMstorm blue.
The k90 is ****ty because the macro portion is all plastic and membrane,,, makes an otherwise attractive looking board feel really cheap..
The k60 is a better choice, more understated and solid, Though it still has rubber membraine keys,, that includes, Escape key, and ins,home,pgup,pgdown,del,end,prnt scrl-lock,pause.  AND the f1-f12 like u said.
And you won't be able to put keycaps on these membrane keys,, Trust me you'll wanna.
