Author Topic: Recommendations?  (Read 1997 times)
Offline biszarerabbit
Recommendations?
« on: Thu, 22 March 2012, 22:44:35 »
So I recently acquired my first mechanical keyboard (cm quickfire with blues) and have fallen in love. I was thinking of maybe getting another mechanical keyboard eventually, and have been looking into more compact layouts such as tenkeyless etc. I was wondering if any of you had any suggestions or recommendations for compact mechanical keyboards; I have been interested in the Noppoo Choc Mini, which greatly appeals to me, but I find layouts such as the poker to be a little too compact.
Recommendations?
« Reply #1 on: Thu, 22 March 2012, 22:46:07 »
Quote from: biszarerabbit;554215
First buy a set of replacement keycaps, that's rule #1
Recommendations?
« Reply #2 on: Thu, 22 March 2012, 22:48:46 »
They are already in the mail :)
Recommendations?
« Reply #3 on: Thu, 22 March 2012, 22:51:14 »
Quote from: biszarerabbit;554219
Only 1 set???
You're behind.
Recommendations?
« Reply #4 on: Thu, 22 March 2012, 22:51:54 »
1 set from ebay, another set from signature plastics
Recommendations?
« Reply #5 on: Thu, 22 March 2012, 22:53:48 »
Quote from: biszarerabbit;554223
Alright,, you win this one,, what u get.
Recommendations?
« Reply #6 on: Thu, 22 March 2012, 22:58:12 »
check bed bath and beyond, they usually always have these in stock!
Recommendations?
« Reply #7 on: Thu, 22 March 2012, 22:58:26 »
Set I got off ebay I found through the great finds section of the forum, and got side printed yellow keys: http://img847.imageshack.us/img847/2357/img4197z.jpg
I also found some keycaps that signature plastics had in excess: http://www.keycapsdirect.com/images/graycompleteLARGER.jpg
But yes I'm still wondering what people recommend for compact/alternative keyboard layouts
Recommendations?
« Reply #8 on: Thu, 22 March 2012, 23:09:46 »
side printed yellow,, not sure how i feel about yellow caps on the quickfire, since it's grey colored. hmmm.... yellow would be great on red, could be done via plastidip
Recommendations?
« Reply #9 on: Thu, 22 March 2012, 23:13:02 »
I was thinking side printed yellows would look good surrounded by black keys
Recommendations?
« Reply #10 on: Thu, 22 March 2012, 23:18:53 »
Quote from: biszarerabbit;554246
we'll find out.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Recommendations?
« Reply #11 on: Thu, 22 March 2012, 23:21:52 »
Quote from: bizarerabbitsucks****;554229
...what?
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline lorem3k
    • http://twitter.com/#!/lorem3k
Recommendations?
« Reply #12 on: Thu, 22 March 2012, 23:25:58 »
Sage advice.
Leopold FC200RT/AWN | Logitech G400 | Sennheiser HD25-1 II | Pounds in the fridge, hundred stacks in the armoire
Recommendations?
« Reply #13 on: Fri, 23 March 2012, 00:13:14 »
Quote from: lorem3k;554261
Sage advice.
what' he ment was,, it's in the BEyond section
Offline Magna224
Recommendations?
« Reply #14 on: Fri, 23 March 2012, 02:18:26 »
My favorite compact mechanical that is common and not too expensive is the SIIG Minitouch you can get em $50-60 or so. Its worth a look but the layout is a little funky.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
Recommendations?
« Reply #15 on: Fri, 23 March 2012, 04:30:28 »
Quote from: Magna224;554388
Yeah after checking that out I don't think I could use it, as the ctrl key is placed a bit differently than I am accustomed to, but thanks for the suggestion!
