Author Topic: cheapest blank keyboards?  (Read 10871 times)
Offline Danny356
« on: Fri, 30 March 2012, 01:49:45 »
Looking to get a cheap blank keyboard for work, It doesnt have to have any bells or whistles or even be mechanical. I just want the cheapest ones available.
when i started googling all i found were stickers to cover up legends on a keyboard, but i want an actual keyboard though.
Offline Erick_C
« Reply #1 on: Fri, 30 March 2012, 01:51:13 »
$10 keyboard + $1 can of spray paint = blank keyboard.
Sorry... I couldn't help myself.
There may not be one.  Even the cheapest keyboards have legends.  Blank keys are more of an "enthusiast" thing to have.  If you really want to do this on a budget, you're going to need to mod.
« Last Edit: Fri, 30 March 2012, 01:54:39 by Erick_C »
Offline Autolyze
« Reply #2 on: Fri, 30 March 2012, 06:48:01 »
You might be best off trying to find a cheap used Cherry MX board on ebay or perhaps the classifieds here, and then getting blank keycaps separately. The Cherry Corp boards in particular can be found for fairly cheap, but you probably want to make sure that what you get would be compatible with a standard set of MX keycaps.
Offline Tony
« Reply #3 on: Fri, 30 March 2012, 07:10:11 »
Get a normal keyboard, then use a razor to clear out all legends on keycaps.
« Reply #4 on: Fri, 30 March 2012, 08:47:16 »
Quote from: Tony;561441
this only works if they're printed,, you can't razor out the etchings very easily,
Offline Desensitised
« Reply #5 on: Fri, 30 March 2012, 10:07:03 »
They do exist:
http://www.getdigital.de/products/Blank_Keyboard/lng/
22 euros,  bought one before I spent the money on a DAS keyboard.
Offline rodya
« Reply #6 on: Fri, 30 March 2012, 13:20:41 »
Quote from: tp4tissue;561483
What cheap rubberdome doesn't use printed keycaps?
« Reply #7 on: Fri, 30 March 2012, 14:07:39 »
Quote from: Desensitised;561540
They do exist:
I think that I have seen another one that was black with a "big-ass" Enter key, and it was even cheaper.
Offline davkol
  •  Post Editing Timeout
« Reply #8 on: Fri, 30 March 2012, 15:59:47 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 13:57:42 by davkol »
