Author Topic: Replacing Cherry MY Switches...Possible?  (Read 132167 times)
  • * Moderator
« on: Sun, 01 April 2012, 22:10:50 »
Sorry if this has been addressed before, but I searched, and I couldn't find it in the wiki, either.
Is it possible to replace all the MY switches on a Cherry Corp board with MX switches from another donor board? Just desolder the MY switches and solder in the MX switches? I ordered a Cherry Corp G81-1822HQMUS from eBay, and I have a Wyse board with Cherry MX Black switches as the donor. I also have a Compaq MX-11800 board with a non-working trackball from which I could harvest MX Brown switches (or the springs, to make ghetto reds). Any thoughts?
  • * Moderator
« Reply #1 on: Sun, 01 April 2012, 22:44:31 »
The Mechanical Keyboard wiki. Specifically, the Geekhack Switch Wiki and link to Cherry MX, ML, MY, etc., but that article seems to be empty.
  • * Moderator
« Reply #2 on: Sun, 01 April 2012, 23:34:47 »
Alas, it's as I suspected. Oh well, after I harvest those sweet DS keycaps it's into the trash bin for Mr. Cherry.
« Reply #3 on: Fri, 06 April 2012, 07:10:54 »
Why would you go through all that work..... ridiculous dedicated you are
« Reply #4 on: Fri, 06 April 2012, 07:31:24 »
Unfortunately, a double-shot Right Shift key from a G8x-18xx won't fit a Compaq MX-11800. 1.75 vs 2 units wide. I don't know why Cherry made them different ...
« Last Edit: Fri, 06 April 2012, 13:39:08 by Findecanor »
Offline mbc
  • -delete-
« Reply #5 on: Fri, 06 April 2012, 13:26:49 »
Of course it will
« Reply #6 on: Fri, 06 April 2012, 13:59:42 »
Quote from: mbc;569044
Of course it will
What are you referring to?
Cherry G8x-18xx vs G8x-118xx keys? I have three G80-18xx and a Compaq 11801 and I know what I am writing about.
