Author Topic: Pressing one side of the spacebar?  (Read 3441 times)
Offline Fluxiantor
« on: Sat, 07 April 2012, 20:09:23 »
I own the Razer BWU, and when I type I press the spacebar with my left thumb. When I type, I press the spacebar down on the left hand side. On my previous, rubber dome keyboard, the spacebar eventually became wobbly due to this and wobbled from side to side. Will this same thing happen due to pressing more on one side of the space key?
Offline Exort
« Reply #1 on: Sat, 07 April 2012, 20:46:06 »
It shouldn't. All type of common mech board have proper support under the keys.
« Reply #2 on: Sat, 07 April 2012, 21:05:00 »
Quote from: Fluxiantor;570218
Make sure to use lithium grease for smooth presses
Offline daerid
    • Rossipedia
« Reply #3 on: Sat, 07 April 2012, 21:34:49 »
In my experience, the BWU has piss-poor stabilizers. You can expect the inserts to come out of the keycap at some point. When that happens, just pop some glue or something inside the slots for the insert and you should be good to go.
« Reply #4 on: Sun, 08 April 2012, 01:32:50 »
Quote from: daerid;570283
ooof, Harsh....
But, yea, just put a little piece of tape on the cross stem of the stabilizer inserts if that's the cause.
You could pop the cap off and take some pictures, that'd help us help you diagnose.
