Author Topic: 20% off RK-9000s - Newegg  (Read 4146 times)
Offline chubbyfatazn
« on: Thu, 12 April 2012, 03:22:36 »
Use code RWPAXEAST2 to get 20% off any RK-9000 keyboard at Newegg. Just got myself my first blue board :D
« Last Edit: Thu, 12 April 2012, 04:07:37 by chubbyfatazn »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Thu, 12 April 2012, 08:24:56 »
FYI - that makes it $90+ship for browns and $80 free shipping for the other 3 switches.
Filco w/ Imsto thick PBT
Offline Rinx7
« Reply #2 on: Thu, 12 April 2012, 10:06:02 »
How long?
Offline Rinx7
« Reply #3 on: Thu, 12 April 2012, 11:31:42 »
Yo Dante, McRip Effect that is all.
Offline alaricljs
« Reply #4 on: Thu, 12 April 2012, 11:32:41 »
Although I do remember hearing that there were some issues on the very first release.  They worked it out and that's something like a year ago now.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #5 on: Thu, 12 April 2012, 11:42:33 »
looks good. sent this to my friend who's missing a 'V' key on his rubber dome (makes playing sc2 with him difficult, to say the least ;)
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #6 on: Thu, 12 April 2012, 11:51:17 »
Quote from: Rinx7;573793
It's not the McRip effect if it's an actual defect that causes the product to cease fuctioning.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Rinx7
« Reply #7 on: Thu, 12 April 2012, 13:26:22 »
Wait was is wrong with it besides a squeaky space bar?
« Reply #8 on: Thu, 12 April 2012, 13:34:14 »
There are problems with the connector failing, just look through the reviews.
« Reply #9 on: Thu, 12 April 2012, 13:47:16 »
I read that you could just tape the cable to the chassis and you should be good. At any rate I'll post again if I have issues with this board. First blues board, so I didn't want to spend too much.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #10 on: Thu, 12 April 2012, 13:49:20 »
Be nice with your keyboard and youll be fine.
Offline Rinx7
« Reply #11 on: Thu, 12 April 2012, 13:52:27 »
Yeah I saw the things about the connector failing I am never going to even move the thing though so it shouldn't be that much of a problem and it has a warranty.
« Reply #12 on: Thu, 12 April 2012, 13:55:12 »
Its because it not recessed and the plug sticks straight out my guess is that people were putting tension on it or bumping the plug while its plugged in with something. One easy way around this is a right or left angle cable which they do have available on newegg.
what do you mean by only soldered into place? that should be more than enough unless your doing stupid stuff with your keyboard... I had one keyboard with one bad switch but it was because i tried pulling the cap and it was extra tight and took the stem with it which i promptly fixed. Truthfully i think its alot of people not knowing what their doing as ive had 5 of these boards with only that one problem.
« Last Edit: Thu, 12 April 2012, 14:01:03 by TheProfosist »
Offline Rinx7
« Reply #13 on: Thu, 12 April 2012, 15:15:57 »
Well I decided to buy one, I don't have much to lose since Newegg's RMA policy is good, anything is going to be way better than the crappy rubber dome I am using right now.
Offline njvz
« Reply #14 on: Thu, 12 April 2012, 18:30:35 »
For the record, I had the USB connectivity problem, it turned out that when a friend who had been borrowing it yanked the cord out while pulling up. In doing so, he had pulled the part of the controller that is connected to the PCB by pins up ever so slightly. After my roommate and I opened the case up and pushed the controller back down on the pins, the board is worked perfectly.
Boards: Noppoo Choc Mini | Leopold TKL | KBTalking Pure | Rosewill RK-9000 | IBM model M | Filco Ninja Majestouch FS
Offline Rinx7
« Reply #15 on: Thu, 12 April 2012, 18:40:57 »
So just be careful and nothing bad happens.
Offline cliffooord
« Reply #16 on: Fri, 13 April 2012, 06:54:52 »
Apparently they can't be shipped to Illinois... lol
« Reply #17 on: Fri, 13 April 2012, 15:28:58 »
LOL, n00bs, Just solder the cable straight into the board..
Offline rknize
    • metaruss
« Reply #18 on: Fri, 13 April 2012, 15:31:03 »
My first Cherry MX board was the 9000BR.  Nice board.  I really like the detachable cable, in fact.
Russ
