Author Topic: Filco Majestouch Only Works Intermittently  (Read 3361 times)
Offline bz0r
« on: Sat, 28 April 2012, 03:25:02 »
Hey there,
New comer here to the forums, although I've used them as a reference point for a long while now.
I've got an odd issue with my 87 key Filco Majestouch (MX Browns from Amazon). It will work for a little while, usually until I restart the computer, and then it will stop working. No matter what I try-- restarting again, un/re-plugging, full shut down etc.-- it won't work for the time being. However, if I use another keyboard for a while (haven't tested the exact time frame thoroughly) and then go back to it, it magically starts again. And the cycle begins again, it will work great until I restart.
This isn't an issue with the computer or USB port. This has occurred over multiple computers and every other USB device works perfectly fine with the same ports.
This person seems to have experienced the same problem:
http://geekhack.org/showthread.php?24903-Broken-Filco-Ideas
I'll send him a PM as well, but if I could possibly arrive at a solution here I feel that it would be good to have for others reference.
Offline pokpok
Re: Filco Majestouch Only Works Intermittently
« Reply #1 on: Mon, 17 December 2012, 15:38:31 »
I have a 10keyless leopold which is pretty much the same as you.
I have the exact same issue usb connectivity is on and off specially when i play game the keyboard become possess.
I tried with a ps2 adapter no change all usb port no change i even went in the bios in pch to change it to 1.1 it was stable for slightly longer but the problem still came back.
I am wondering if there is any way to fix this issue i bought this for more then 100$ and it lasted me about 10 months.
« Reply #2 on: Mon, 17 December 2012, 15:45:09 »
Hey there,
Amazon has a great replacement policy if it died within 30 days..
Offline pokpok
« Reply #3 on: Mon, 17 December 2012, 15:51:03 »
I also tried with a different mini usb cable and still have the same issue.
Is there any way to fix this like opening the keyboard and replace a parts or reseting something in it ?
Must be pcb related.
« Last Edit: Mon, 17 December 2012, 15:56:10 by pokpok »
Offline tauburn
« Reply #4 on: Mon, 17 December 2012, 22:02:09 »
I see so many people having problems with Filcos. Are they just built poorly or is it because so many people have them that it seems like they cause lots of problems?
« Reply #5 on: Mon, 17 December 2012, 23:46:33 »
For every person here with Filco problems there are probable thousands not here with no problems at all.
And lots here with no problems.
Filco are generally reliable, so you don't get to hear when they work well, only when they stop working.  And this, being a keyboard enthusiast forum, tends to attract those seeking assistance.
Offline canon.tk
« Reply #6 on: Tue, 18 December 2012, 08:38:10 »
I own nine Filco keyboards and all work just fine.
Filco Majestouch 104 Cherry MX Black; Filco Majestouch 87 Ninja Cherry MX Brown; Filco Majestouch Indigo Blue 104 Cherry MX Brown; Filco Majestouch 2 104 Cherry MX Red; Leopold 87 Otaku Cherry MX Brown; Leopold 87 Cherry MX Brown; Razer Black Widow Ultimate
Offline tauburn
« Reply #7 on: Tue, 18 December 2012, 13:33:46 »
ok thats what i figured
Offline pokpok
« Reply #8 on: Sat, 29 December 2012, 04:02:20 »
Any help ?
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #10 on: Sun, 30 December 2012, 00:12:06 »
The only problem I ever had with a Filco was the USB cable.  As mentioned, try replacing it.
