Author Topic: Siig Reserrection  (Read 910 times)
Offline drteming
Siig Reserrection
« on: Sat, 28 April 2012, 20:01:14 »
Well I bid and got 2 Siig Minitouch keyboards (Here).  The cords were cut and one of them was missing the F1 key cap.  When I got them, they were otherwise in great shape and very clean.  There was only some minor smudges on the cases which cleaned up easily with some 90% isopropyl alcohol.  When I opened the keyboards, I found that the cut cords were attached to a 5-pin molex connector.
I took the pins out of the molex connectors and recrimped a couple of donor cables onto them.  With the help of a multimeter, I figured out which wire was which and reattached the molex connectors.  The keyboards worked 100%!  Though I still prefer the buckling springs of my trusty model M's, the white ALPs are fun to type on.  Now I gotta find a F1 keycap.  I thought I had a source but alas, no.
« Last Edit: Sat, 28 April 2012, 20:04:30 by drteming »
1391401 Blue, 1391401 White, Terminal M "ANSI", Siig Minitouch x 2, Dell AT101W
Siig Reserrection
« Reply #1 on: Sun, 29 April 2012, 01:47:22 »
Quote from: drteming;585170
I always fear semen when it comes to used boards.
