Author Topic: Ducky Shine Stabilizer removal  (Read 3613 times)
Offline Sloth
« on: Sat, 11 August 2012, 23:22:02 »
hello I haev a ducky shine green backlit keyboard and I really really dislike the stabilizers on the shift and spacebar. Is there a way to remove these and make them feel like the rest of the keys? Also is it safe? Thanks!
Offline alaricljs
  • I be WOT'ing all day...
Re: Ducky Shine Stabilizer removal
« Reply #1 on: Sat, 11 August 2012, 23:34:22 »
They are there because you need them.  If you happen to hit those keys directly above the switch 100% of the time, then you might be able to get away with removing them.
Filco w/ Imsto thick PBT
Offline lazerpointer
  • ya gotta stay phresh
« Reply #2 on: Tue, 25 September 2012, 23:27:38 »
Ahhh the precise, machine-like response, Lol. One question though, OP.  What do you mean by "don't like" the stabilizer?
i type, therefore i geekhack
« Reply #3 on: Tue, 25 September 2012, 23:37:27 »
Welcome to Geekhack!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 25 September 2012, 23:49:15 »
Just keep using it they will break in. If you are impatient try greasing them.
« Reply #5 on: Tue, 25 September 2012, 23:56:37 »
If you do take them out, put a 1x or 1.25x keycap on there.
I'd keep the stabilizers. Other than the spacebar, which is supposed to feel different, they are not that heavily used.
« Reply #6 on: Wed, 26 September 2012, 04:25:09 »
Do that Korean mod thing, where you cut the little nubs off the side of the stabilizers.
See if that helps..
Offline Hyde
  • White Tofu Extraordinaire
« Reply #7 on: Wed, 26 September 2012, 15:37:28 »
Come to think about it how hard is it to do that mod.  I'm considering getting a Ducky but in case I don't like the cherry stabilizer I might do that.
I've seen the video where they clip the stem/bars, but how hard is it to get that stem/bar out from the housing?
