Author Topic: Plate mounted or PBC ?  (Read 4883 times)
Offline Rafen
« on: Fri, 07 September 2012, 11:30:23 »
Do you guys like plate mounted or PBC keyboards better? I have been typing on both lately and I find that I type better and I enjoy the feel of the PBC better than the plate mounted boards that I have or had.
I would like to hear your thoughts on this.
Thanks,
Rafen
Re: Plate mounted or PBC ?
« Reply #1 on: Fri, 07 September 2012, 13:48:24 »
trivial difference.
Technically the plate mounted is more mechanically sound, because it ensures that the switch doesn-t twist when you type on it.
That said, it can-t actually twist by all that much, no matter how it-s mounted
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Fri, 07 September 2012, 13:49:58 »
tp - your keymap get broke?  - instead of '
Some people claim that PCB mount is 'softer' on your fingers because the PCB is more forgiving than a plate, but that also depends on how the PCB is mounted into the case.
Filco w/ Imsto thick PBT
« Reply #3 on: Fri, 07 September 2012, 14:29:07 »
LOL, no i-m on my laptop, it-s a different layout than my desktop, because my mother uses this thing, and the - is where the ' is.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #4 on: Fri, 07 September 2012, 14:52:54 »
You share the same user account as her?
Bore Awards
Offline dabeshu
« Reply #5 on: Fri, 07 September 2012, 14:53:31 »
It depends on many things I guess.
  • RIP
    • Boring twaddle
« Reply #6 on: Fri, 07 September 2012, 15:01:09 »
I got my first PCB mount the other week, a G80-3000LQCDE with clears. When I type too hard on a FILCO with blues or browns, the sharp impact of bottoming out is quite uncomfortable. I find that the Cherry keyboard doesn't present hard landings no matter how hard I hit the keys. I don't have a PCB-mounted keyboard with browns or blues, or a plate-mounted keyboard with clears for comparison, so I can't be sure whether it's the clear switch, or the PCB mounting, that makes it softer. (Bottoming out clears is in itself fatiguing for your hands as they're so stiff.)
My main concern with PCB mount is that removing keycaps is risky as you're pulling on the solder joint instead of the steel plate. The first thing I did after opening the box was wrench off the Esc keycap and replace it with a Panic keycap, before realising that I have to treat it with a lot more care!
PS you mean PCB: printed circuit board. You're probably mixing that up with PBT (polybutylene terephthalate), the sought-after material for keycaps.
Bore Awards
Offline Rafen
« Reply #7 on: Fri, 07 September 2012, 16:10:32 »
Sorry about the PCB thing.
Like you said when typing on a PCB board you don't have that harsh feeling if you press the key too far down. Does anyone know of a list that contains where a board is plate mounted our PCB?
« Reply #8 on: Fri, 07 September 2012, 16:13:01 »
LOL, mom not into keyboards. She-s princess type, 3rd child
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #9 on: Fri, 07 September 2012, 16:14:20 »
Plate mounted switched feel and sound FAR better than anything on a PCB, especially with o-rings and thick caps.
« Reply #10 on: Fri, 07 September 2012, 16:15:04 »
Even if such list existed, the difference in the base design could make pcb mounted feel like plate, and plate mounted feel like PCB
So, there wouldn-t be any guarantees.
Offline daerid
    • Rossipedia
« Reply #11 on: Fri, 07 September 2012, 16:29:08 »
Plate by far, except for with Blacks. Blacks I like PCB mounted better.
  • RIP
    • Boring twaddle
« Reply #12 on: Fri, 07 September 2012, 16:46:55 »
I meant, the only excuse you have for using the same login account is if she's obsessed with Mac OS 8 or Windows 95 and you have a real relic of a computer. Windows 7 even has per-user DPI now, as well as supporting multiple concurrent sessions on a domain! (I did try the Mac OS 9 multi-user feature, but it was horrible.)
That's a Cherry fault. ALPS switches don't have that problem when plate mounted. The PCB mounting does muffle the sound of bottoming out – even a Realforce has a cleaner sound than a G80-3000, yet the latter still sounds nice and metallic and springy compared an average dome switch keyboard.
I don't have an issue with Cherry stabilisers either – I haven't even noticed any difference in the keys at all.
Bore Awards
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #13 on: Fri, 07 September 2012, 16:59:13 »
PCB mounted all the way! It's a much softer typing experience. I prefer cherry brand cherry boards, and cherry stabilizers to costar stabilizers too.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
« Reply #14 on: Fri, 07 September 2012, 17:34:05 »
Ah, well, i guess you haven-t read my qwerty for men layout thread in ergonomics.
My default layout is very different from standard key placement, and can only be achieve by registry edit. So windows reconizes all signals from keyboard from any keyboard as my special layout on my upstairs desktop. this downstairs laptop is family share, so I can-t be using my custom layout.
Offline alaricljs
« Reply #15 on: Fri, 07 September 2012, 17:38:19 »
Time to get a filco TKL and wait for bp's controller.  :)
  • RIP
    • Boring twaddle
« Reply #16 on: Sat, 08 September 2012, 15:31:20 »
I take it this must be one of those changes that requires editing HKEY_LOCAL_MACHINE instead of HKEY_CURRENT_USER … It's truly depressing how many times Microsoft themselves write a feature that only checks HKLM instead of trying HKCU first. That said, keyboard layouts are a per-user setting and have been for many years, so one solution to this is to design and install a new keyboard layout. John Sullivan created a new layout "United Kingdom (International)" that I have installed on both my home PC and work and set under my user account. (However, it lacks so many common typographical symbols that I've complemented it with an Autohotkey script that I have since extended with all sorts of useful tweaks like ^D to close console windows "just like" *NIX shells.)
From the sounds of it, creating a new layout is complicated, but if you were to follow this approach, you could then install it trivially onto every computer you use. That likely requires admin privileges initially, but it won't affect anyone else further on. If you find yourself hacking up the Registry, you're usually doing something wrong.
Bore Awards
Offline Slavfot
« Reply #17 on: Sun, 09 September 2012, 15:36:13 »
I like PCB mount better 'cus it has a nicer sound when bottoming out and it's easy to change springs and stems.
The only bad thing with PCB-mounted switches is if you are to remove the keycaps you need to be really carefull so that you don't open the switch when trying to remove the keycap.
« Reply #18 on: Sun, 09 September 2012, 18:02:31 »
I would be afraid of the PCB traces delaminating after many strain cycles. Based on all the cyclic loading and shear flow, I'd imagine they wouldn't last as long, and although the benefits of a softer bottoming out are good, they're effectively negated by "proper" typing methods on mechanical keyswitches.
PCB mounted browns on my huge G80-8113 feel better than the plate mounted ones on my WASDkeyboard, but I like the design of plates more.
Actually, My "ideal" keyboard design is like a DOX plate, where it's bent over, making a stand as well. Simple, elegant, effective.
Offline Velma
« Reply #19 on: Mon, 10 September 2012, 10:02:54 »
some switches differ quite alot depending on the mounting. Blacks are probably the most extreme, PBC mounted blacks are much much softer (kinda feel like plated mounted reds) while plate mounted blacks are the stiffest switches out there and generaly unfavored by most people
Offline mangostea
« Reply #20 on: Tue, 11 September 2012, 01:40:42 »
Could you explain how blues, reds and browns feel on PCB mounted vs. plate mounted?
