Author Topic: Facit upgrade  (Read 2752 times)
Offline vils
Facit upgrade
« on: Fri, 07 September 2012, 16:25:31 »
Did a week-end work for a friend and was paid in computer parts. So now my old Facit machine will get an upgrade.
From 2GB of ram to 16 from Corsair. Definitely a overkill but why not. The weakest part in the system, a GeForce 8400 gs, will be replaced by a GeForce GT 430 from Asus (silent).
For more boost I'll install the OS on a new Intel 520 SSD 120gb. Finally I will change my CPU-cooler from a Noctua NH-C12p to a Noctua NH-L12 to solve some clearance and airflow issues.
I'm also building on a new screen mount. After that only a good 4:3 monitor remains to be obtained.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Re: Facit upgrade
« Reply #1 on: Fri, 07 September 2012, 17:37:46 »
Exactly what sorta "work" did you "do" for this "friend"??
Offline vils
Re: Facit upgrade
« Reply #2 on: Fri, 07 September 2012, 18:01:10 »
Painted a floor. :) Almost 20 hours of work with all preparations.
Re: Facit upgrade
« Reply #3 on: Fri, 07 September 2012, 20:28:41 »
So the two of you "painted the floor" together. I see.....  ;D
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: Facit upgrade
« Reply #4 on: Fri, 07 September 2012, 22:29:04 »
Was it anything like the potter's wheel scene from Ghost? Which one was Demi?
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline vils
Re: Facit upgrade
« Reply #5 on: Sat, 08 September 2012, 04:45:03 »
You all have to much imagination.
Re: Facit upgrade
« Reply #6 on: Sat, 08 September 2012, 10:12:51 »
As long as it was all consensual.
At least that-s what I-m assuming. :-*
