Author Topic: Is there a way to grease a topre keyboard?  (Read 2600 times)
Offline Neo.X
« on: Thu, 13 September 2012, 10:57:03 »
Just got  my RF 87U silent from  a member here, it's awesome!! Very comfortable and quiet to type on.
  :D :D:D
The only key that generates some squeaky noise is the Backsapce key. For a MX keyboase, normally I just use some grease on the stablizer and it works like a charm. For a topre switch, is there a way to grease it?
Thanks
« Last Edit: Thu, 13 September 2012, 13:37:10 by Neo.X »
All those keyboards will be lost in time....
Offline Neo.X
Re: Is there a way to grease a topre keyboard?
« Reply #1 on: Thu, 13 September 2012, 13:07:50 »
bump. any help?
« Reply #2 on: Thu, 13 September 2012, 13:47:33 »
oh , ho ho ho, you need RO59, quite hard to get in the states.
and you're supposed to lube the "Shaft" of the keystem with it. mmmmm.... shaffft..
Offline AKIMbO
  • HHKBro
« Reply #3 on: Thu, 13 September 2012, 13:55:11 »
You can try a tiny amount of white lithium based grease on the slider. Should be able to pick up that type of grease at home depot for uber cheap.
| KBD75 (box reds)
Offline Neo.X
« Reply #4 on: Thu, 13 September 2012, 13:57:53 »
sounds difficult.  :( :(
I guess I will just enjoy me new RF. :D :D
« Reply #5 on: Thu, 13 September 2012, 14:03:39 »
No nononononono, grease was not designed for lubrication of vertical walls. Especially where the bottom and top are NOT sealed. DO NOT do this.
You need dry lubricant...... also, DO NOT use pencil led, it rubs off too quickly,
