Author Topic: Help a total n00b out?  (Read 3086 times)
Offline mars-bar-man
« on: Sun, 16 September 2012, 18:38:49 »
Well, I'm still relatively new to this mech board malarky.
I've seen a lot of keycaps for sale with things like R1, R2 etc next to them, I figured the R means Row, but the number bit has me stumped..
Does R1 means that's the F row? Or the bottom row with the space bar etc?
Mainly asking because I've got a KBT Pure on the way and I fancy getting creative with some engraved keycaps.
KBC Poker w. MX Blues
Offline sth
  • 2 girls 1 cuprubber
Re: Help a total n00b out?
« Reply #1 on: Sun, 16 September 2012, 18:43:35 »
http://catb.org/~esr/faqs/smart-questions.html
i'll be nice this time though :)
R1 means the function and number row for SP-produced keys
R1 means the ctrl/alt and shift/zxcv row for OEM-produced keys, including WASD.
it's not always clear but figuring out the source of the keycaps will usually tell you the proper notation.
« Last Edit: Sun, 16 September 2012, 18:49:53 by sth »
« Reply #2 on: Sun, 16 September 2012, 18:43:41 »
This should help you out: WASD keyboard layout
EDIT: Sth is right, here is example of SP layout with Rows labeled: Deskthority Wiki
« Last Edit: Sun, 16 September 2012, 19:18:24 by metalliqaz »
« Reply #3 on: Sun, 16 September 2012, 18:56:00 »
Cheers Metal! :)
sth, I tried Googling, but having just finished work, my mind wasn't in 'logic' mode, so I ended up finding out nothing. Thanks for the help though!
Offline sth
« Reply #4 on: Sun, 16 September 2012, 19:07:17 »
keep in mind the row difference i mentioned. WASD uses OEM numbering. Most of our Group Buys come from SP so they are the opposite.
« Reply #5 on: Sun, 16 September 2012, 19:10:43 »
Thanks, I'm looking to buy a load of caps from there anyway, I'll wait a little longer before I delve into the depths of Group Buys..
« Reply #6 on: Sun, 16 September 2012, 19:13:21 »
I can't believe you had to ask that question. google generation. LOLOL
Offline sth
« Reply #7 on: Sun, 16 September 2012, 19:14:24 »
your troll fu is hella weak these days bro
« Reply #8 on: Sun, 16 September 2012, 19:16:16 »
Unhelpful post is unhelpful. Not everyone is l33t in teh world of Google. I bow down to your superior intellect. ****.
Offline sth
« Reply #9 on: Sun, 16 September 2012, 19:17:47 »
don't, he's a chode. lurk moar!
« Reply #10 on: Sun, 16 September 2012, 19:22:07 »
LOL, this n00b...
I' haven't been here long, but I've at least surpassed this sth clown in keyboard prowess and knowledge. ;D
Offline sth
« Reply #11 on: Sun, 16 September 2012, 19:22:56 »
ur rite  :'(
« Reply #12 on: Sun, 16 September 2012, 19:23:19 »
ur rite  :'(
Finally, some recognition.
when I first joined I was at 90 to 100 wpm, I stand now at 130wpm  AND mind full of keyboard facts. and Keyboard PREJUDICES.  >:D
