Author Topic: Are key cool boards any good?  (Read 2972 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Mon, 24 September 2012, 19:30:04 »
I'm just wondering about the quality. Is it any good?
Also, is the space bar propitiatory like the Leopolds?
This specifically.
http://www.ebay.com/itm/Key-Cool-87-Mechanical-Gaming-keyboard-Cherry-MX-Red-W-White-body-/290671062176?pt=PCA_Mice_Trackballs&hash=item43ad586ca0
« Last Edit: Mon, 24 September 2012, 20:11:35 by Lethal Squirrel »
Offline kinruan
  • SWAG=Specially Weaponized Asian Grandma
Re: Are key cool boards any good?
« Reply #1 on: Mon, 24 September 2012, 20:34:41 »
it is 21 keys NKRO under USB and full NKRO under Ps/2 due to the PCB design, therefore, master core suddenly doesn't work sometimes, and it means u need to return it back to the seller to change a new one. it is not a big deal since only several of this case is occurred. Keycaps are abs and just fine. wires are good, not like damn Rosewill.
If the world ends tomorrow, what should we have for dinner tonight?
Offline kinruan
« Reply #2 on: Mon, 24 September 2012, 20:36:30 »
btw the PCB is high qualified, u can only break it by punching it.
  • I <3 60%
« Reply #3 on: Mon, 24 September 2012, 20:56:05 »
Thanks for the info. are these boards plate mounted by the way? I'm assuming they are.
Offline kinruan
« Reply #4 on: Mon, 24 September 2012, 21:53:46 »
hard to say. it is fine.
« Reply #5 on: Mon, 24 September 2012, 22:06:51 »
I feel like those images were doctored to make the Keycaps color more similar to the base color, or vice versa
In reality, there's probably a good shade difference. BEWARE.
Also, Bad review
http://deskthority.net/news-reviews-f4/keycool-87-blue-mx-t2650.html
« Reply #6 on: Mon, 24 September 2012, 22:13:22 »
I don't have one, but I do believe they are plate mounted.
Also, don't buy from Qtan's ebay store. Buy from his other store. or hit up his subforum here on GH
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/key-cool-87-gaming-cherry-mx-s/lid=26561692
(looks like it's $10 less)
Offline polpo
    • http://polpo.org/
« Reply #7 on: Mon, 24 September 2012, 22:13:45 »
I've had a KeyCool 84 for about a month and have been happy with it. I have had a problem where the Ctrl key sticks, and I have to hit it again to turn it off. It's happened about 3 times since I've gotten the keyboard, and I use it all day in my coding job. It's been better than the Noppoo that I replaced with the Keycool.
I'm almost certain they're plate mounted, but I can verify tomorrow when I get to work. If you look at the picture I have of my keyboard you can see the plate.
« Last Edit: Mon, 24 September 2012, 22:15:48 by polpo »
Matias Mini Quiet Pro / DSI SMK-88 (Cherry Black) / IBM Model M (10 Jul 86) / ThinkPad Travel Keyboard with Ultranav
  • I <3 60%
« Reply #8 on: Mon, 24 September 2012, 22:19:13 »
That is indeed plate mounted : )
And thanks for the link dorkvader.
« Last Edit: Mon, 24 September 2012, 22:22:06 by Lethal Squirrel »
Offline kinruan
« Reply #9 on: Mon, 24 September 2012, 22:33:30 »
oops. plate mounted means the steel board. sorry, i am a chinese guy and just getting in Gh.
